  3. Replace library name and cell name of standard cells in...
  • Views 23251
Replace library name and cell name of standard cells in schematic
naresh9005
naresh9005 over 5 years ago
Hi
we are trying to write one skill script to replace the library name and cell name of an instant in the schematic i.e. we have standard cell with instant name  as "I1" it is from the library "STANDARDCELL_1" and cell name is "INV_F1", this instant library name should replace with "STANDARDCELL_2" and cell name should append with  "AB", that is cell name should replace with  "INV_FIAB". i have many instances like this with different cell names,  please help with this problem.
Regards
Naresh
  • naresh9005
    could some one help me on this , can i use "schHiReplace" function ?
    Andrew Beckett over 5 years ago in reply to naresh9005
    I'd probably do it by writing a simple bit of SKILL - your requirement was a little vague (which was why I didn't reply sooner). What are you expecting to provide to the program? A list of instance names? Or do you want to replace all instances from a particular library with cells from a different library with the suffix added to each?
    In general, changing the master (symbol) for a specific instance would be done by setting ~>master to the database object of the new cellView (you can't directly set libName/cellName/viewName); if you want to change all instances of a particular lib/cell/view in a schematic you'd probably use dbSetInstHeaderMasterName.
    I think it might end up being a bit tortuous to do this with schHiReplace.
  • naresh9005
    naresh9005 over 5 years ago in reply to Andrew Beckett
    Thank you for your reply,
    Actually i have two standard cell library's in our design one is "STANDARDCELL_1" and second one is "STANDARDCELL_2". Both of the library's contains standard cells like Inverters, ANDgate,ORgate .....etc,but there is a naming difference for cells, if the inverter name is "INV1_F1" in  "STANDARDCELL_1" library,  the same inverter name  will be "INV_FIAB" in "STANDARDCELL_2" library. similarly  if the Andgate name is "AND_F1" in  "STANDARDCELL_1" library,  the same ANDgate  name  will be "AND_FIAB" in "STANDARDCELL_2" library.
    Now in my design few instances(symbol) are referring from "STANDARDCELL_1" library, so these instances library name should changes to  "STANDARDCELL_2" and the cell name should be append with "AB", if the cell name is "INV_F1", then it should change to "INV_F1AB".
    Finally our skill script should be able to find the instances from "STANDARDCELL_1"  and replace each instant library with "STANDARDCELL_2"
    and cell name of the instant should append with "AB".
    EXAMPLE :
    INPUT:        OUTPUT:
    INSTANT NAME: I1                                                        INSTANT NAME: I1
    LIBRARY NAME: STANDARDCELL_1                           LIBRARY NAME: STANDARDCELL_2
    CELL NAME: INV_FI                                                       CELL NAME: INV_FIAB
    Regards
    Naresh
    Naresh,
    This code should help you:
    procedure(CCFreplaceStdCells(@key
            (cvId geGetEditCellView())
            (fromLib "STANDARDCELL_1")
            (toLib "STANDARDCELL_2")
            (suffix "AB")
      let((newCellName)
        foreach(instHeader cvId~>instHeaders
          when(instHeader~>libName==fromLib && instHeader~>instances
            newCellName=strcat(instHeader~>cellName suffix)
            dbSetInstHeaderMasterName(
              instHeader
              toLib
              newCellName
              instHeader~>viewName
        t
    Then all you need to do is (with the schematic open and in the current window):
    CCFreplaceStdCells()
    You might also want to change the library names it is looking for, so you could do:
    CCFreplaceStdCells(?fromLib "origLibName" ?toLib "newLibName")
    There's also the ability to pass ?cvId so it doesn't have to be a schematic open in a window (it could have been opened with dbOpenCellViewByType), or to use a different suffix via ?suffix.
  • naresh9005
    Thank you Andrew, above code is working perfectly fine thank you.
    i have similar case, where i need to replace the "STANDARDCELL_3" library has to replace with "STANDARDCELL_4"
     library cells . below are cell names compression between two library cells
    STANDARDCELL_3                                                      STANDARDCELL_4
    cell names:        cell names:
    inv_f1_1p8v        inv_f1_ab1p8v
    inv_f2_1p8v        inv_f2_ab1p8v
    mux_f2_1p8v_e                                                           mux_f2_ab1p8v_e
    and_f1_1p8v_h                                                            and_f1_ab1p8v_h
     all the standard cell names contain "1p8v" string in the cell names in "STANDAREDCELL_3" , this string has to replace with "ab1p8v" string for the cell names in "STANDAREDCELL_4".
    EXAMPLE :
    INPUT:        OUTPUT:
    LIBRARY NAME: STANDARDCELL_3                          LIBRARY NAME: STANDARDCELL_4
    CELL NAME: inv_f1_1p8v                                              CELL NAME: inv_f1_ab1p8v
    i was trying break the cell names, but my script is not working  , could you please help me with this problem .
    Regards
    Naresh
    Naresh,
    Completely untested, but something like this should work:
    procedure(CCFreplaceStdCellsPat(@key
            (fromLib "STANDARDCELL_3")
            (toLib "STANDARDCELL_4")
            (pattern "1pv8")
    	(with "ab1pv8")
      let((newCellName pat)
        pat=pcreCompile(pattern)
            newCellName=pcreReplace(pat instHeader~>cellName with 1)
              instHeader
              toLib
              newCellName
        t
