  3. How can I get waveforms from item in OCEAN ?
  • Views 14120
ichiro
ichiro over 5 years ago
Hi
I'd like to get waveforms from item in OCEAN script.
The "nth" syntax is only able to get as strings not as waveforms.
Is there a another way to get them?
Ichiro
    Andrew Beckett over 5 years ago in reply to ichiro +1
    There's nothing wrong with nth - the issue is that you've used ' (quote) to create your list, which means that none of the values within the list are evaluated - so it's a list of two sublists, each of…
  • ichiro
    OUT_g=/VT("OUT")
    foreach(item '(
    (1 OUT_g CNT1_g)
    (2 IN_g CNT2_g)
    );item
    awvPlotWaveform(
            currentWindow()
            list(nth(1 item) nth(2 item))
    Above worked well when list is given waveform name directly.
    awvPlotWaveform(
            currentWindow()
            list(OUT_g CNT1_g)
    There's nothing wrong with nth - the issue is that you've used ' (quote) to create your list, which means that none of the values within the list are evaluated - so it's a list of two sublists, each of which contain an integer and two symbols. So you're getting a symbol because of that.
    Instead, if you use:
    foreach(item list(
        list(1 OUT_g CNT1_g)
        list(2 IN_g CNT2_g)
    then the rest of the code should work.
  • ichiro
    ichiro over 5 years ago in reply to Andrew Beckett
    Hi , Andrew
    Thank you for your nice advice. I'll try it soon.
    Ichiro
  • ichiro
    ichiro over 5 years ago in reply to ichiro
    I confirmed working well above.
