  3. Using a look-up-table LUT based calibration in maestro ...
  • Views 12616
Using a look-up-table LUT based calibration in maestro assembler
SVehringBST
SVehringBST over 5 years ago
Dear community,
is there a royal-road to implement a look-up-table (LUT) based calibration in maestro assembler?
At this moment, I do a pre-cal simulation of a 6-bit-DAC and generate a 4-bit LUT by comparison with desired values.
LUT values are used with calcVal in a post-cal simulation.
My open issue is that the LUT values are still in 6-bit and not equidistant.
I would love to map the LUT values to 4-bit and equidistant.
I believe there must be a more easy way of LUT-based calibration.
Can you please help me?
Soenke
