  3. Layout SKILL - ungroup
  • Views 2872
RodrigoPeres
RodrigoPeres over 5 years ago
Hi everyone,
Do you know if there is a way to ungroup a FigGroup in layout in SKILL?
I could not find it so far.
Thanks in advance,
Rodrigo
  • dmay
    dmay over 5 years ago +1
    Hi Rodrigo, You have two options. The simplest is to just use dbDeleteObject on the figGroup id. This does not delete the objects in the group like it would if you deleted the group interactively. I don…
  • dmay
    Hi Rodrigo,
    You have two options. The simplest is to just use dbDeleteObject on the figGroup id. This does not delete the objects in the group like it would if you deleted the group interactively. I don't think this has adverse side effects (I'm sure someone will chime in if it does).
    The second option is to use dbRemoveFigFromFigGroup on each of the figs in the groupId~>figs. In the end, you'll still want to delete the figGroup id.
    Derek
  • RodrigoPeres
    RodrigoPeres over 5 years ago in reply to dmay
    Hi Derek,
    Great! Both sound great. Thanks a lot for the help =)
