  3. How to access to the inside node signal
  • Views 13171
ichiro
ichiro over 5 years ago
I'd like to know how to access the inside node signal in monte carlo script.(MDL)
Although I tried "sig=V(NEW_SW.Gate)" and "sig=V(NEW_SW:Gate)", it didn't work well (error).
Can I access lower node voltage?
Ichiro
    If it is a node voltage, then sig=V(NEW_SW.Gate) should work. In other words, there is an instance called NEW_SW and there's a node within that called "Gate". I just tried it, and it works fine. If it…
    I just tried it, and it works fine. If it doesn't, you may need to provide an example to illustrate the problem (the spectre netlist and the MDL file).
  • ichiro
    ichiro over 5 years ago in reply to Andrew Beckett
    Yes, it works well. I put in wrong syntax.
    Ichiro
