  3. Why couldn't I get the evaluation result?
  • Views 2096
ichiro
ichiro over 5 years ago
I could get NANs result with the below message.
WARNING (MDL-360): line `41': MDL expression for identifier 'Iq_avdd' can not be evaluated, because 'I(V_avdd:MINUS)' is invalid.
where,
41: export real Iq_avdd = I(V_iavdd:MINUS)@500u
V_avdd is a instance name that is kind of "vdc" set 0V
Best regards,
Ichiro
    Andrew Beckett over 5 years ago in reply to ichiro +1
    I was about to suggest exactly this. You can't use the schematic names for primitive devices (in fact you always need to use netlist names anyway, but mostly they are the same). For primitive devices you…
  • ichiro
    I found the correct way that is "MINUS"-->"p",
    I was about to suggest exactly this. You can't use the schematic names for primitive devices (in fact you always need to use netlist names anyway, but mostly they are the same). For primitive devices you'd see the terminal names in the "spectre -h vsource" output, but you can also use the position - so V_iavdd:2 would work too.
    Anyway, glad you resolved it.
  • ichiro
    ichiro over 5 years ago in reply to Andrew Beckett
    Thank you for your nice idea, it's very useful info for me.
    Ichiro
