  3. Order of let() and procedure()
  • Views 17247
Michael Kolesnik
Michael Kolesnik over 5 years ago
Is there a recommended order of let() and procedure()?
I have seen it both ways:
procedure(myFunction()
let( (x y z )
...code...
);let
);procedure
let( (x y z )
...code...
);procedure
);let
it seems that with let() first you can have more than one procedure in the code that can share the variables defined in let()
    Well, these mean different things - so it's not a matter of a recommended order. I use both depending on what I'm trying to achieve. The creation of functions within a let is something that only has…
    The creation of functions within a let is something that only has meaning in SKILL++ mode (e.g. when you have a .ils suffix to your source file) and only then will it make the functions locally scoped within that let and share variables across the functions within the let.
    If the let is within the function, then the variables are scoped to that function, either lexically (in SKILL++ mode) or dynamically (in SKILL mode).
    This is beyond the scope of something that I can reasonably explain the full details of lexical and dynamic scoping here - it is covered in other resources elsewhere though...
  • Michael Kolesnik
    Michael Kolesnik over 5 years ago in reply to Andrew Beckett
    Do you have any pointers/links to the other resources?
    Are they SKILL resources or lisp resources? I did not really see any details in the SKILL User Guide
    Andrew Beckett over 5 years ago in reply to Michael Kolesnik
    SKILL resources.
    I touch on it (briefly) during my video Writing Good SKILL Code and it's also in the About SKILL++ and SKILL chapter of the SKILL Language User Guide.
    This blog posts might be a useful start too:
    • SKILL for the Skilled: What is SKILL++?
