  3. Save as an OCEAN Script using SKILL
  • Views 14568
MauMarulanda
MauMarulanda over 5 years ago
I am trying to save the full session (ASSEMBLER) using a command with a specific name.
I am trying to replicate the icon named "save as ocean script," the only different is that I need to automate it. (I am creating a menu for it inside the same maestro window)
saveOcean(fname)
The maestro window will be open.
I have tried asiGetSession("current_window"), then asiWriteOceanScript(fname session). However this only outputs the equivalent of a small run. I need the full maestro ocean_xl script. Basically, the same function that the icon "save as ocean script" does.
Mauricio
    Hi Mauricio, sess=axlGetWindowSession() axlWriteOceanScriptLCV("this.ocn" axlGetSessionLibName(sess) axlGetSessionCellName(sess) axlGetSessionViewName(sess)) This will work for Assembler too - note…
    Hi Mauricio,
    This will work for Assembler too - note that the "axl" functions are still relevant for ExplorerAssembler since it's built on the same infrastructure as ADE XL. There are maestro-specific functions too where needed (with the "mae" prefix), but we've not replicated all the axl functions to mae as it wasn't needed.
  • MauMarulanda
    MauMarulanda over 5 years ago in reply to Andrew Beckett
    Excellent, works like a charm.
