  3. Where to find default lsw layer order
  • Views 13108
psill000
psill000 over 5 years ago
Where or how do you find the default lsw layer order?
Paul
    Paul,
    It comes from the tech file. If leLSWLayers is defined, then that is used, otherwise it uses the order in the techLayerPurposePriorities subsection of the layerDefinitions section (this also defines the drawing order - for more information see the documentation).
