  3. List of environment variables for defaults in virtuoso
  • Replies 8
  • Views 22715
venkmanbuster
venkmanbuster over 5 years ago
I am wondering if there is a document that lists all environment variables used in virtuoso.
For example, I don't want Spec/Weight and Min/Max displayed for every result in ADE XL/Maestro. I want them disabled by default. Do you know if there is a way?
Thanks!
    Andrew Beckett over 5 years ago in reply to venkmanbuster +2
    That's odd. The menu is definitely there in ICADVM18.1-64b.500.9 : Maybe you have an outdated or site-customised "ciw.menus" file which doesn't contain this entry. You can check that by typing in the…
    It's this: envGetVal("adexl.gui" "detailViewShowDefault") envSetVal("adexl.gui" "detailViewShowDefault" 'string "\"Test\" \"Corners\" \"Scalar Expressions\" \"Waveform Expressions\" \"Signals\" \"Corner…
    Andrew Beckett over 5 years ago in reply to venkmanbuster +1
    This is defined by the "tsg" template you're using. The definitions are defined by a SKILL variable tsgTemplateMasters which can be redefined in your .cdsinit - here's the default definition from <ICinstDir…
    It's this:
    envSetVal("adexl.gui" "detailViewShowDefault" 'string "\"Test\"  \"Corners\" \"Scalar Expressions\" \"Waveform Expressions\" \"Signals\" \"Corner Expressions\" \"Post Run Results\" \"Device Checks\" \"User-Defined Columns\" \"Run Statistics\"")
    in IC6.1.8 you can use Options->cdsenv editor and search for "column" for example. It found this (more by luck than judgement, as "Column" is in the list of values)
  • venkmanbuster
    venkmanbuster over 5 years ago in reply to Andrew Beckett
    Thanks for the reply. I appreciate it. The skill code worked. However, I can't find cdsenv editor in Options menu. I am using ICADVM181.090.
    I am also interested to know if there is a way to open config in edit mode by default (generally it opens in read only mode and I have to manually change it to edit mode) when I right click a test on Assembler and select Design option. Please let me know if there is a way. Thanks for your time!
    Maybe you have an outdated or site-customised "ciw.menus" file which doesn't contain this entry. You can check that by typing in the CIW:
    ddGetStartup("ciw.menus")
    If so, you probably need to get that updated or synchronised with the version in <ICinstDir>/tools/dfII/etc/tools/menus/ciw.menus
    You can invoke it by calling startCdsenvEditor() in the CIW.
    For opening in editable mode, there's a cdsenv for this too covered in this article:  Open Design in Tab from Data View opens schematic and configuration in read only mode (hint: search in the cdsenv editor for "openDesign" and you'll find the way to change the access mode to "a").
    • Vote Up +2 Vote Down
  • venkmanbuster
    startCdsenvEditor() in the CIW worked! Thanks so much Andrew! I appreciate it.
  • venkmanbuster
    venkmanbuster over 5 years ago in reply to venkmanbuster
    Also, do you know the env variable so that I can have @cellName rather than @partName when creating symbol by default? I tried to search for this on cdsenv list, but couldn't.
    This is defined by the "tsg" template you're using. The definitions are defined by a SKILL variable tsgTemplateMasters which can be redefined in your .cdsinit - here's the default definition from <ICinstDir>/tools/dfII/samples/local/schConfig.il :
    tsgTemplateMasters = list(
    	list("digital" (prependInstallPath "samples/symbolGen/default.tsg"))
    	list("analog"  (prependInstallPath "samples/symbolGen/artist.tsg"))
    	list("artist"  (prependInstallPath "samples/symbolGen/artist.tsg"))
    	list("PCB"     (prependInstallPath "samples/symbolGen/package.tsg"))
    	list("metric"  (prependInstallPath "samples/symbolGen/metric.tsg"))
    If you copy the default.tsg from <ICinstDir>/tools/dfII/samples/symbolGen/default.tsg to your own location somewhere, and edit this to replace [@partName] with [@cellName], then add the new file to the tsgTemplateMasters variable:
    	list("mydigital" "/path/to/your/own/default.tsg")
    Finally set this env var in your .cdsinit to pick your own to be used by default:
    envSetVal("schematic" "tsgTemplateType" 'string "mydigital")
  • venkmanbuster
    Hi Andrew, Thanks so much! Do you know the env variable to show just the Used layers by default when I open layout xl suite on virtuoso?
    envSetVal("layout" "pteUsedOnlyScope" 'boolean t)
