  3. a procedure to generate a binary waveform for plot
  • Replies 9
  • Views 17714
LDIL
LDIL over 5 years ago
Hello all.
I want to create a binary displayed waveform in maestro, using SKILL.
All I saw is how to create integer waveforms, but I want them displayed in binary, by default.
    Andrew Beckett over 5 years ago in reply to LDIL +1
    You can do this with awvCreateBus() - the third argument is the radix to use. Note that there was a bug where the radix wasn't being honoured but that was fixed in IC6.1.7/ICADV12.3 ISR12, so some time…
    In the VIVA SKILL manual it says that it returns an o_bus. Did you try it? I didn't really have time today, but quickly put together an example showing that it works perfectly in a Explorer output expression…
    In SKILL, every function returns something, so that's clearly an error in the OCEAN manual. Unfortunately many of the functions in the OCEAN documentation are a replica of functions documented elsewhere…
    What do you mean by a "binary displayed waveform"?
  • LDIL
    LDIL over 5 years ago in reply to Andrew Beckett
    Hi. The equivalent of looking at Analog To Digital in VIVA, of a bus, and then display, with a binary radix. I want to input a few waveforms and get their name
    You can do this with awvCreateBus() - the third argument is the radix to use. Note that there was a bug where the radix wasn't being honoured but that was fixed in IC6.1.7/ICADV12.3 ISR12, so some time ago.
  • LDIL
    Hi Andrew. It looks From the documentation, it appears that a bus is created, but it does not say how is that displayed, or if it can be fed to subsequent OCEAN code. It returns no value. and I would like it to behave as an Output Expression in Maestro, in the sense that one can right-click it, and re-display, at will. This usually happens if the OCEAN code returns a waveform or a scalar.
    Did you try it? I didn't really have time today, but quickly put together an example showing that it works perfectly in a Explorer output expression. Add the attached library to your cds.lib and then open LDIL/busexample/maestro and run the simulation.
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/48/LDIL_5F00_bus.tgz
  • LDIL
    In the VIVA documentation it is indeed stated returns a value, in  OCEAN it is stated that the function does not return any value, which is odd for a functional language. I am writing the code s we speak. Thanks.
    In SKILL, every function returns something, so that's clearly an error in the OCEAN manual. Unfortunately many of the functions in the OCEAN documentation are a replica of functions documented elsewhere, but sometimes something went wrong when copying from one to another, or they got fixed in one place and not the other.
  • LDIL
    Hi A.
    It works like a charm. I did not use your code, just tool the function, and assumed that the manual's entry about the return value was wrong. May I suggest a CCR for the manual?
    The best thing is to use the “Feedback” on either the manual page in support.cadence.com or within cdnshelp. That will generate a task to get the documentation fixed.
