  3. Replace via array with one large via rectangle per inst...
  • Views 15592
Replace via array with one large via rectangle per instance
socratic
socratic over 5 years ago
I would like to write some SKILL code to replace arrays of vias with one large via layer rectangle (as shown below).
I was trying to do something like another post about something similar, but his code was not doing the same thing that I am looking to do. https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill/31242/merge-via-arrays
I will post my code to show my approach. I am getting an error in leSearchHierarchy of "Invalid bBox", and I am having trouble understanding why.
Does anyone have suggestions on this approach or a better approach?
    Andrew Beckett over 5 years ago in reply to socratic +1
    The brackets aren't quite right, but I didn't get the error you said - for me it "worked" except if you had multiple vias it ended up merging them all together, which I don't think you wanted. So instead…
  • socratic
    procedure(vias_to_rect(lib cell)
    let((cv wid cont via1 via2 via3 via4 via5 via6 via7 via8 mergecont mergevia1 mergevia2 mergevia3 mergevia4 mergevia5 mergevia6 mergevia7 mergevia8)
    cv=dbOpenCellViewByType(lib cell "layout" "" "a")
    ;Flatten the layout
    foreach(fig1 cv~>vias
    leFlattenInst(fig1 30 t t t nil t t)
    ;Search and store individual vias
    via1=leSearchHierarchy( cv cv~>bBox 0 "rectangle" list( list( "layer" "==" list( "VIA1" "drawing" ) ) ) )
    ;Merge via arrays
    mergevia1=dbLayerSize(cv '("VIA1" "drawing") via1 0.04)
    ;Find the bottom left and top right corners of via array
    RightMax=nil
    LeftMin=nil
    TopMax=nil
    BottomMin=nil
    foreach(fig mergevia1
    when(fig~>objType=="rect"
    if(RightMax==nil
    then
    RightMax=xCoord(cadr(fig~>bBox))
    LeftMin=xCoord(car(fig~>bBox))
    TopMax=yCoord(cadr(fig~>bBox))
    BottomMin=yCoord(car(fig~>bBox))
    Right=xCoord(cadr(fig~>bBox))
    Left=xCoord(car(fig~>bBox))
    Top=yCoord(cadr(fig~>bBox))
    Bottom=yCoord(car(fig~>bBox))
    if(Right>RightMax then RightMax = Right)
    if(Left<LeftMin then LeftMin = Left)
    if(Top>TopMax then TopMax = Top)
    if(Bottom<BottomMin then BottomMin = Bottom)
    ;Resize merged via to have the same area as the original array of vias
    LowerLeft=LeftMin:BottomMin
    UpperRight=RightMax:TopMax
    dbCreateRect(cv list("VIA1" "drawing") list(LowerLeft UpperRight))
    ;Delete original vias
    foreach(fig via1
    dbDeleteObject(fig)
    The brackets aren't quite right, but I didn't get the error you said - for me it "worked" except if you had multiple vias it ended up merging them all together, which I don't think you wanted. So instead of the leSearchHierarchy using cv~>bBox, I used the bBox of the specific via you were iterating over. I tidied the code up (sorted out the local variables, indentation and so on) and added the missing parentheses. It then works fine...
    procedure(vias_to_rect(lib cell @optional (viaLPP '("VIA1" "drawing")))
      let((cv viaBBox  via1 mergevia1 Bottom BottomMin Left LeftMin Right RightMax Top TopMax LowerLeft UpperRight)
        ;Flatten the layout
          viaBBox=fig1~>bBox
          via1=leSearchHierarchy( cv viaBBox 0 "rectangle" list( list( "layer" "==" viaLPP ) ) )
          ;Merge via arrays
          mergevia1=dbLayerSize(cv viaLPP via1 0.04)
          RightMax=nil
          LeftMin=nil
          TopMax=nil
          BottomMin=nil
              if(RightMax==nil
              then
              ; delete merged via
              dbDeleteObject(fig)
          when(LeftMin && BottomMin && RightMax && TopMax
            dbCreateRect(cv viaLPP list(LowerLeft UpperRight))
          foreach(fig via1
            dbDeleteObject(fig)
  • socratic
    socratic over 5 years ago in reply to Andrew Beckett
    Oh man, I see my mistake now. Your solution worked brilliantly! Also taught me to use better naming and indentation in the future too. Thanks so much for your time and help!
