  3. Search all cells in all libraries for layout instance
  • Subscribers 152
  • Views 15910
Michael Kolesnik
Michael Kolesnik over 5 years ago
I would like some hints for SKILL code.
I am writing a function which can be summarized " where are all the places this instance is used".
I want to search all cells in all libraries .
The only code I have seen that is close are these two:
CCSfindInstCellLib = find a instance in ONE library
CCSFindCellInLibrary = finds a CELL in all libraries
I have been trying to combine these two but have no luck so far.
My plan is something like this:
foreach(library...
       foreach(cell in library... search for instance "inv2"
            print the results.
  • psill000
    psill000 over 5 years ago +1
    Not sure the criteria of how you want to search of whole string or substring, but will provide a skeleton to started findCellStr = substring searching schLayBool = t schematic nil layout findCellStringAllLib…
  • psill000
    findCellStringAllLib("INV" t)
    procedure(findCellStringAllLib(findCellStr schLayBool)
    let( (cellDb fndList instList)
    foreach(lib sort(ddGetLibList()~>name nil)
        printf("Searching %s\n" lib)
       foreach(cName ddGetObj(lib)~>cells~>name
           if(schLayBool then
                 when(ddGetObj(lib cName "schematic")
                          cellDb = dbOpenCellViewByType(lib cName "schematic" "schematic" "r")
                          instList = setof(i cellDb~>instances dbIsId(i) && rexMatchp(findCellStr i~>cellName))~>cellName)
          else when(ddGetObj(lib cName "layout")
                        cellDb = dbOpenCellViewByType(lib cName "layout" "maskLayout" "r")
    when(instList
               fndList = cons(strcat(lib " " cName) fndList))
               instList = nil
    if(fndList then
            printf("%L\n\n" sort(fndList nil))
    else printf("%s not found\n" findCellStr))
    )); end of findCellStringAllLib
  • Michael Kolesnik
    Michael Kolesnik over 5 years ago in reply to psill000
    That worked perfect except for one unseen situation - during the run, memory usage jumped from 2gb to 27gb before I stopped it. It was probably due to the "dbOpen" function which loads the cell into memory, and was loading hundreds of cells into memory. I will see if there is a purge command to purge each cell after it is done.
