  3. need to get bbox of shapes from a abeLayer.
  • Replies 7
  • Views 17119
Leonardo Vinci
Leonardo Vinci over 5 years ago
Greetings everyone,
I have an abeLayer (geoLayer:NULL) which has certain number of different different rectangles. I want the bBox or any coordinates of those rectangles. I am unable to fetch their coordinates since I cannot apply bBox function on them since its an abeLayer and not any list or array.
How can I access the bBox of the shapes for any abeLayer?
I hope you understand my query well.
Leo
    Leo,
    There's no direct function to do it, but it's easy enough to write one - see this earlier post.
  • Leonardo Vinci
    Leonardo Vinci over 5 years ago in reply to Andrew Beckett
    Hi Andrew,
    I dont want all the shapes named in "layerName".
    I already have filtered out some of the shapes of my interest in one of the abeLayer.
    From that abeLayer I want the shapes and not all the shapes of "layerName".
    Leo
    Andrew Beckett over 5 years ago in reply to Leonardo Vinci
    Leo,
    It's a pretty obvious change to the code to make this do what you want - surprised you couldn't just write your own code based on my example. Simply remove the initialisation and retrieval of the layer from the cellView, and you'd get this:
    procedure(abGetAbeLayerBBox(layer)
        let((iter tile ollx olly ourx oury)
            iter=abeTileIterator(layer)
            while(tile=iter->next
                destructuringBind(((llx lly) (urx ury)) tile->bbox
                    ollx=if(ollx min(ollx llx) llx)
                    olly=if(olly min(olly lly) lly)
                    ourx=if(ourx max(ourx urx) urx)
                    oury=if(oury max(oury ury) ury)
            when(ollx
                list(ollx:olly ourx:oury)
  • AurelBuche
    AurelBuche over 5 years ago in reply to Andrew Beckett
    By looking at your code I realize destructuringBind can also split lists!
    I guess I never tried it that way even though it is the behaviour I have been looking for and always achieved it with a second let...
    It seems extremely convenient but its quite surprising as it is not at all described in the documentation
    I thought destructuringBind was only a macro generating a lambda and applying it to its second argument (I see by expanding it in your case that it is also recursive!?)
    Has it always done that or was it implemented in a recent version? (I plan to use it from now on but I don't want to lose backward compatibility with some previous versions)
    Aurel
    Andrew Beckett over 5 years ago in reply to AurelBuche
    Hi Aurel,
    It's always been supported. I'll file a CCR to get the documentation improved - it's not great right now because it doesn't cover any of that and gives a minimal example. This is kind of the point of the word "destructuring" in the function name!
  • AurelBuche
    By "split lists" I meant hierarchical ones, I have been using it for a long time with flat ones
    I will use it in more cases thanks to you
    Cheers,
    Aurel
    Hi Aurel,
    I filed CCR 2443771 on this. BTW for the benefit of anyone else, there's a video on the support site which covers destructuringBind and gives a few examples of more complex usage: SKILL destructuringBind function (Video) (I pointed the tech pubs folks to that!).
