  3. How to create wave bus with bundled signal v("/data<7:0...
  • Views 2476
How to create wave bus with bundled signal v("/data<7:0>")?
Martinsh
Martinsh over 5 years ago
I want to create a signal bus with following skill script, the input is a signal bundle, but it doesn't work. It will not plot a single bus but 8 buses for data<7>, data<6>, ..., data<0> seperatelly.
awvCreateBus("bus" list( awvAnalog2Digital( v("/data<7:0>" ?result "tran-tran") nil nil 0.5 nil "centre")  ) "Hex")
How to realize this function with input signal of v("/data<7:0>" ?
    Probably ought to be a built-in way of doing this, as it strikes me as being a rather common thing to want to do. However, you can use the SKILL code in this post (abWaveToList - the second bit of code…
    Probably ought to be a built-in way of doing this, as it strikes me as being a rather common thing to want to do. However, you can use the SKILL code in this post (abWaveToList - the second bit of code), and then use:
    awvCreateBus("bus" mapcar('cadr abWaveToList(awvAnalog2Digital(v("/data<7:0>" ?result 'tran) nil nil 0.5 nil "centre"))) "Hex")
