  3. Waveforms opened from Assembler not garbage-collected properly...
  • Views 12837
Waveforms opened from Assembler not garbage-collected properly?
smikes
smikes over 5 years ago
I have an ADE Assembler bench that runs across a few modes and corners, saving some waveforms. I tried writing a script to generate and export plots after the sim is done. The script works fine, but while I was building it I was running it multiple times, and eventually started getting warnings that the system was low on memory. The combined results databases for the sim are 5.8GB.
On startup, my Virtuoso session uses less than 1GB. I simplified the script to just the part that creates a couple waveforms:
testName = "TRAN"
sess = axlGetWindowSession()
hist = axlGetCurrentHistory(sess)
resultsDir = axlGetHistoryResultsDir(hist)
openResults(strcat(resultsDir "/psf/" testName))
Rdiv = clip(vtime('tran "/Tout")/vtime('tran "/Tin") 4.4n nil)
Fin = clip(1/vtime('tran "/Tin") 4.4n nil)
closeResults(resultsDir)
After running this one time, memory usage jumps to 15GB (not sure if this is reasonable or not for the two waveforms, there are 153 total transient sims of different lengths)
I ran the code above multiple times, this shows the memory usage after the 1st, 2nd, and so on
    PID USER     %MEM        RSS COMMAND
20607 stevenm  23.1   15299552 virtuoso
20607 stevenm  47.8   31544408 virtuoso
20607 stevenm  58.4   38564348 virtuoso
20607 stevenm  83.1   54870100 virtuoso
Why is this happening? Shouldn't the garbage collector be freeing the old memory when the variables are re-assigned?
$> virtuoso -W
sub-version  ICADVM20.1-64b.500.16
    It's not quite as simple as garbage collection of the variables triggering this. There's some caching of waveform data to avoid re-reading the waveforms from disk, and the actual waveform object itself is small - it's just a pointer to two vectors plus some attributes. In general, closing the ViVA window helps, plus closing the ADE session, but I think it's probably going to be worth you contacting customer support so that this can be investigated together with an application engineer. Whilst things have got better in terms of memory growth for cases like this in versions throughout ICADVM18.1/20.1, there's a tradeoff of not deteriorating performance by closing and flushing data too quickly. We may not have got that tradeoff right for your situation, but it would be good to explore that in your case.
