  3. listing of default bindkeys for any generic cadence virtuoso...
  • Views 18229
listing of default bindkeys for any generic cadence virtuoso installation
malcolm70
malcolm70 over 5 years ago
Hi Cadence - where can I find a listing of the default bindkeys which would be loaded into a user environment under any generic cadence installation
for virtuoso versions after say 18 ? ( stuff loaded before a IT / cad redefine of keys to local environments )
I'm looking specifically for the bindkey strings for what I have known as Shift<Key>F and Ctrl<Key>F  which both seem to function as the display heirarchy
levels keys, one being display start level 0 to stop level 0 and the other start level 0 to stop level ( usually ) 31.
what are the function call defaults usually assigned to those 2 keys ?
thanks!
Malcolm
  • skillUser
    skillUser over 5 years ago
    Hi Malcolm,
    In my editor I see those bindkeys as the following SKILL definitions:
    Shift-F => hiGetCurrentWindow()->stopLevel = dbGetMaxHierDepth()-1
    Ctrl-F => leSetStopLevelToEditLevel(hiGetCurrentWindow())
    You may also like to use the + / - keys:
    leIncrementStopLevelByOne(hiGetCurrentWindow())
    leDecrementStopLevelByOne(hiGetCurrentWindow())
    You should be able to find these definitions in the file: `cds_root virtuoso`/tools/dfII/samples/local//leBindKeys.il
    Best regards,
    Lawrence.
    Andrew Beckett over 5 years ago in reply to skillUser
    Actually, Lawrence (warning, Andrew being pedantic), those are the sample bind keys and not actually what is loaded by default.
    The default would be those found in <ICinstDir>/share//cdssetup/dfII/bindkeys/ - for example Layout.il in that directory.
    Note that if you have a .cadence/dfII/bindkeys dir in any of your "setup.loc" locations then those will be used instead - you can check that in the CIW by typing:
    ddGetStartup(".cadence/dfII/bindkeys/Layout.il")
    In general the content is the same (hence my comment being pedantic), but there's alway a chance they might have deviated.
