  3. Open PDF file using Skill in Cadence 20.1
  • Views 14215
kdolan
kdolan over 5 years ago
HI,
Is there a skill command to open and view a pdf file from within Cadence 20.1?
Keelan
    Keelan, Depending on which PDF viewer you have on your system, it's likely to be something like this: system(lsprintf("evince %s" pdfFileName)) where pdfFileName is variable containing the path to…
    Keelan,
    where pdfFileName is variable containing the path to the PDF file. Here I'm using the evince PDF viewer.
  • kdolan
    kdolan over 5 years ago in reply to Andrew Beckett
    Works perfectly! I was unaware of the "system" function.
    Thanks Andrew!
