  3. Detect highlight and optional remove dangling/floating ...
  • Subscribers 152
  • Views 5093
Detect highlight and optional remove dangling/floating layout
mfaisal
mfaisal over 5 years ago
Anyone have a good skill approach to detecting and removing floating or dangling layout.
I using this command but the result its delete all layout.
cvId=geGetEditCellView()
shapeList = setof( x cvId~>shapes !x~>NetName )
foreach( shapes shapeList dbDeleteObject(shapes)
);foreach
my idea to select and delete all layer without connection(floating)
Faisal
  • mbracht
    mbracht over 5 years ago +1
    Hi Faisal, There is no database object by the name of NetName. It needs to be net. shapeList = setof( x cvId~>shapes !x~>net ) Max
    Andrew Beckett over 4 years ago in reply to LakshmanQual +1
    It's not that clear what you want, but you'd need to write some code that traversed the hierarchy and did similar checks at each level, presumably. There are many, many examples of showing recursive hierarchy…
  • mbracht
    Hi Faisal,
    Max
  • LakshmanQual
    LakshmanQual over 4 years ago in reply to mbracht
    Hi Max,
    Thanks for the code.
    But this code is finding the nets which dont have connectivity also. But how to find nets which are not connected to any devices as well?
    Probably:
    shapeList=setof(x cvId~>shapes !x->net || !(x->net->instTerms))
  • LakshmanQual
    LakshmanQual over 4 years ago in reply to Andrew Beckett
    Hi Andrew, this is working good in same hierarchy. But what if we want to get till lower hierarchies also?
    It's not that clear what you want, but you'd need to write some code that traversed the hierarchy and did similar checks at each level, presumably. There are many, many examples of showing recursive hierarchy traversal approaches on this forum.
  • LakshmanQual
    Thanks Andrew for the suggestion and quick response!!
