  3. leMergeShapes alternative for PCELL code (compatible with...
  • Views 14031
leMergeShapes alternative for PCELL code (compatible with steam-out)
Sheppie
Sheppie over 5 years ago
I'm working on code for a layout PCELL. In this code I use leMergeShapes.I just found out that this procedure is not known at stream-out (it's not part of the allowed list of procedures as can be found here:support.cadence.com/.../techpubDocViewerPage. This is unfortunate, since I need those shapes to be merged.
What alternative method should I use which is compatible with stream-out and which achieves the same? The original shapes are created using dbCreateRect().
With kind regards,
Sjoerd
    Sjoerd, You could use dbLayerOr(). This generates a new set of merged shapes (so you'd need to delete the source shapes). Andrew
  • Sheppie
    Sheppie over 5 years ago in reply to Andrew Beckett +1
    Hi Andrew, Thanks for the confirmation, that I'm smart! Will tell my wife... With kind regards, Sjoerd
    Sjoerd,
  • Sheppie
    Thank you Andrew.
    So simple, yet so effective. Works really well.
    One question: now I delete the original shapes simply by using a foreach() with dbDeleteObject(). Is there a smarter method to deleting all shapes at once?
    With kind regards,
    Sjoerd
    Andrew Beckett over 5 years ago in reply to Sheppie
    Hi Sjoerd,
    No, that is the smart method ;-)
  • Sheppie
    With kind regards,
    Sjoerd
