  3. skill code to select a signal/label in schematic and change...
  • Views 3546
skill code to select a signal/label in schematic and change it
ExcaIibur
ExcaIibur over 5 years ago
The pieces I have put together so far is:
  • cvID~>signals
  • chObjPropForm->labelText->value=...
For example, I want to select a label name called "X<2>" and then change it to "X<3>". What I am still missing is the step of how to select the label..
Is it possible? If yet, indication of how to do so is appreciated.
    You don't really need to select the labels in order to change them. You can directly change theLabel attribute as follows: procedure(CCFchangeWireLabel(from to @optional (cv geGetEditCellView())) foreach…
        foreach(shape cv~>shapes
    	when(shape~>objType=="label" && shape~>lpp=='("wire" "label") &&
    		shape~>theLabel==from
    	    shape~>theLabel=to
        t
    So use this code by simply calling:
    CCFchangeWireLabels("X<2>" "X<3>")
  • ExcaIibur
    ExcaIibur over 5 years ago in reply to Andrew Beckett
    Thanks.
