  3. Error on creating form
  • Views 14151
MollyMeow
MollyMeow over 5 years ago
I used a skll CreateMultiLabel
but is not work
hiCreateCyclicField(
?name 'spFieldDirection
?prompt "Direction"
?defValue "Vertical"
?choices list("Vertical" "Horizontal")
CIW output error message:
Field is “spFieldDirection”
Error * hiCreateCyclicField : value must be contained within the list of choices
If anyone know the solution/fix for this problem, please let me know..
(use 5141)
reguards,
Molly
    Hi Molly, I just tried that in IC5141, and it worked fine (I'm using sub-version 5.10.41.500.6.151): hiCreateAppForm(?name 'MyForm ?fields list(hiCreateCyclicField( ?name 'spFieldDirection ?prompt…
    Hi Molly,
        ?prompt "Direction"
    hiDisplayForm(MyForm)
    I did wonder whether you might need to use ?value as well, but if not specified it should default to ?defValue.
  • MollyMeow
    MollyMeow over 5 years ago in reply to Andrew Beckett
    It work! but I got new error ...
    *Error* dbCreateLabbel : argument #5 shourld be a string ( type template = "dglttttn")  -nil
    *Error* load : error while loading file - "*loadstring"
    but in skill #5 is string already
    dbCreateLabel( cv LswEntryLayer ptsLabel Text Justification Rotation FontName FontSize)
    #5  I think is Justification (if I'm wrong please correct thanks)
    all argument are String type
    so I really confuse...
    Andrew Beckett over 5 years ago in reply to MollyMeow
    Well, if that's your code, and Justification is a variable, presumably it is nil and not a string (should be something like "lowerLeft" or "centerRight").
    There's not enough information in your post to identify the error, since you only included one line and didn't show how the variables in the arguments are set.
  • MollyMeow
    I am not sure if it is a version issue
    Other users can use this code..
    Molly
    Molly,
    I loaded that code in both IC618 and IC5141, and then called spHiCreateMultiLabel(). I hit F3 and filled in the form, and then clicked on the layout. It worked fine. Looking at the code, I can't see how it could fail the way you described.
