  3. Change behavior according to current directory
  • Views 13403
ichiro
ichiro over 5 years ago
Hi all,
I'd like to change behavior according to where I run a ocean script. And I got what I'd like to do with next script.
Can I use "case" in case of adding "proc_C" without using else if...else if...?
if( nindex(getWorkingDir() "proc_A")
then
        process_select=0    ; proc_A
else
        process_select=1    ; proc_B
regards,
Ichiro
    You can't use a case() function for something that is in an indeterminate position like this - because you need nindex() to find a string which presumably could appear anywhere throughout. However, you…
    You can't use a case() function for something that is in an indeterminate position like this - because you need nindex() to find a string which presumably could appear anywhere throughout. However, you could use cond() instead to avoid a multiway if-then-else:
    cond(
      (nindex(getWorkingDir() "proc_A")
        process_select=0
      (nindex(getWorkingDir() "proc_B")
        process_select=1
      (nindex(getWorkingDir() "proc_C")
        process_select=2
      (t ; catch-all
        process_select=3
    You could also avoid the variable assignment in each branch simply by doing:
    process_select=cond(
       0
        1
        2
      (t ; catch-all
        3
    Hope that helps!
  • ichiro
    ichiro over 5 years ago in reply to Andrew Beckett
    It's a very good idea in case of addition of new process.
    Ichiro
