  3. Question about create wire in schematic with SKILL
  • Views 18819
morrris
morrris over 5 years ago
Hi, Cadence Family
I have a question about create wire in schematic with SKILL.
I have created the schematic named "test" where I have 1 cell ( with two port named "src" and "dst") and 1 pin which connected to the "src" port by schCreateWire.
When I directly open the "test" cell in read-only, it look fine.
But if I add the "test" cell in another schematic then descend it, the wire which created by schCreateWire disappeard.
But the connectivity info still there.
How could I do to keep the wire there?
I would appreciate it if any one could guide me a little ~
Virtuoso version IC6.1.7-64b.500.21
Here is my code:
let((library pcellId)
  library="test"
  cell="test"
  unless(ddGetObj(library) error("Couldn't open library %L" library))
  ;Schematic
  pcellId=pcDefinePCell(
    list(ddGetObj(library) cell "schematic" "schematic")
    ;Formal parameters
    ( (uLib1 "basic") )
    ;Build itself
    let(()
      pcCV=pcCellView
      netPadId=dbCreateNet(pcCV "PAD")
      masterIopinCv=dbOpenCellViewByType(uLib1 "iopin" "symbolr" nil "r")
      PadId=schCreatePin(pcCV masterIopinCv "PAD" "inputOutput" nil -0.2:0 "R0")
      masterCv=dbOpenCellViewByType(uLib1 "cds_thru" "symbol" nil "r")
      instId=dbCreateInst(pcCV masterCv "X1" (0:0) "R0" 1)
      dbCreateInstTerm(netPadId instId dbFindTermByName(masterCv "src"))
      dbCreateConnByName(netPadId instId "src")
      ;PAD
      pinSrc=centerBox(car(dbFindTermByName(masterCv "src")->pins)->fig->bBox)
      padId=schCreateWire(pcCV "route" " full" list(pinSrc list(-0.25 0)) 0.0625 0.0625 0)
      schCreateWireLabel(pcCV car(padId) list(plus((xCoord pinSrc) -0.0625) plus((yCoord pinSrc) 0.0625)) "PAD" "lowerRight" "r0" "stick" 0.0625 nil)
      dbClose(masterIopinCv)
      dbClose(masterCv)
      t
    );end let
  );end pcDefinePCell
  dbSetConnCurrent(pcellId)
  schCheck(pcellId)
  dbSave(pcellId) dbClose(pcellId)
  ;Symbol
    list(ddGetObj(library) cell "symbol" "schematicSymbol")
    ;Formal parameters
    let(()
      pcCV=pcCellView
      dbCreateRect(pcCV list("text" "drawing") list(0.125:0 0.875:0.5))
      dbCreateRect(pcCV list("instance" "drawing") list(0:0 1:0.5))
    );end let
  );end pcDefinePCell
);let
    Other than a couple of typos in the code (which I'm sure you must have fixed - " full" had a space and "r0" should have been "R0"), I'm not sure precisely why it is failing, other than the fact that sch…
    Other than a couple of typos in the code (which I'm sure you must have fixed - " full" had a space and "r0" should have been "R0"), I'm not sure precisely why it is failing, other than the fact that sch* functions are not legal in a PCell anyway. Since they are not valid in PCells (mainly because they wouldn't exist in all executables - for example, the CDL netlister wouldn't work on such a PCell, nor would executables like dbAccess, which doesn't have the schematic APIs), I changed the code to use appropriate db functions instead (I also added local variables in the let, and also commented out a couple of unnecessary lines):
      library="mylib"
      cell="testschpc"
      ;Schematic
        ;Formal parameters
        ( (uLib1 "basic") )
        ;Build itself
        ; ANDREW - added local variables
        let((pcCV netPadId masterIopinCv PadId wireId masterCv instId
              pinSrc labelId)
          pcCV=pcCellView
          ;PAD
          ; ANDREW - create wire and label using PCell-safe functions
          ; sch functions not allowed in PCells
          wireId=dbCreateLine(pcCV '("wire" "drawing") list(pinSrc list(-0.25 0)))
          wireId~>net=netPadId
          labelId=dbCreateLabel(pcCV '("wire" "label")
            "PAD" "lowerRight" "R0" "stick" 0.0625
          labelId~>parent=wireId
          dbClose(masterCv)
          t
        );end let
      );end pcDefinePCell
    ; ANDREW - these are not needed
    ;  dbSetConnCurrent(pcellId)
    ;  schCheck(pcellId)
      ;Symbol
        ;Formal parameters
        let(()
          pcCV=pcCellView
        );end let
      );end pcDefinePCell
    );let
  • morrris
    morrris over 5 years ago in reply to Andrew Beckett
    Hi, Andrew
    Thank you for your explanation.
    It works fine and helps me a lot ~
    Morrris
