  3. Export waveform expression to csv in assembler using the...
  • Subscribers 152
  • Views 14057
Export waveform expression to csv in assembler using the expression name
vpn2441139
vpn2441139 over 5 years ago
Hi!
I have a waveform expression defined as such:
xyz = dB20((vh("hb" "outp" '(1 1 0)) - vh("hb" "outn" '(1 1 0))))
I am trying to export this to a CSV file using awvSaveToCSV function:
awvSaveToCSV(dB20((vh("hb" "/outp" '(1 1 0)) - vh("hb" "/outn" '(1 1 0)))) "file_name.csv") works just fine but when I use the expression name:
awvSaveToCSV(xyz "file_name.csv") I get the error: *Error* eval: unbound variable - xyz
Is there a way to export the waveform expression using the name? I have tried using abDumpWaveformsToVCSV but get a similar error.
Thank you!
  • marcelpreda
    marcelpreda over 5 years ago
    Hi there,
    Most likely you are ding something wrong. Probable you get the waveform in some procedure and try to save it in some other procedure where xyz variable is not visible.
    In my case I have
    myWave = i("/I_Diode_c_dio_pndio/I_monitor/p")
    srrWave:0x0f32b020
    awvSaveToCSV(myWave "myFile.csv")
    t
    and it is working just perfect, "sub-version  IC6.1.7-64b.500.23 "
    Best Regards,
    Marcel
