  3. change the Pcell parameter
  • Views 13826
naresh9005
naresh9005 over 5 years ago
I am trying to change the Pcell parameters using skill script,  EX:  I have Pcell  Name PMOS, and i would like  to change the width & length to desired value.
I am not able to access the Pcell update script from this link  https://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNu%20mber=11018344 , not sure what is the reason.
could you please help me with the script.
Regards
Naresh
    Naresh,
    You've ended up with a space in the URL for some reason. It should be https://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11018344
    Note that this code is not specifically related to PCells - the idea is that it's for when you have a CDF parameter computed by a CDF callback - and that needs to be triggered programmatically for correct behaviour. The device may or may not be a "pcell" but if you need these dependent parameters correctly triggered, using something like this code would help (it was written by me and has evolved over 25 years or so!)
