  3. fail to define new view type on libmgr
  • Views 14764
mlea11
mlea11 over 5 years ago
I was trying to define a new view type on libMgr, that should be use for gds file. the file should be open with a graphical tool wrraper called run_ic_workB
quick search on the forum gave me everything I need, i made the required customization... but somehow it fail.
i doubled checked myself few times -  but it seems that this "gdsLay" type would not go in to the view drop box.
I was wonder if any of the gentlemen here can see the issue .
DataFormat run_ic_workB {
Pattern = block.gds;
Default_Editor = run_ic_workB;
dfII_ViewType = gdsLay;
Co_Managed = block.gds master.tag prop.xx;
ViewAlias {
gdsLay=run_ic_workB;
Tool run_ic_workB {}
I also define the required trigger  , and trigger reg:
procedure( CCSOOoAppDataTrig(argList)
let( (mode(getq(argList accessMode)) libName(getq(argList libName))
cellName(getq(argList cellName)) viewName(getq(argList viewName))
fileId fileName)
if(fileId=ddGetObj(libName cellName viewName "*") then
when(fileId
fileName=ddGetObjWritePath(fileId)
system(sprintf(nil "run_icw %s" fileName))
);when
else
fileId = ddGetObj( libName cellName viewName "block.gds" nil "r" )
fileName=strcat(ddGetObjWritePath(fileId) )
) ;if
t
) ;let
) ;procedure CCSOOoAppDataTrig
; Dummy triggers
procedure( CCSOOoAppTrig(argL) t )
procedure( CCSOOoEnableTrig(@optional argL) t )
procedure( CCSOOoRegister()
deRegApp(
?appName "run_ic_workB"
?appTrigger 'CCSOOoAppTrig ; Dummy function
?dataTrigger 'CCSOOoAppDataTrig
?enableTrigger 'CCSOOoEnableTrig ; Dummy function
?viewType "gdsLay"
?widgetType "none"
);procedure CCSOOoRegister
; Register the triggers
CCSOOoRegister()
envSetVal("graphic" "viewNameToTypeList" 'string "document pdf, gdsLay gds" )
  • mlea11
    Update: I was able to solve 50% of the issue - now once a gds lib  exist, and inside it there is a view in the right pattern : block.gds - virtuoso uses the app "run_ic_workB"  - and the layout open successfully.
                 I guess this mean that all 3 triggers were registered correctly. now i still left with the issue that , on library manager , i still dont see under  View type ( when creating a new cell view) the required "block" type
    here is the new code:
    DataFormat GDSII {
    Pattern=block.gds;
    Preferred_Editor=run_ic_workB;
    dfII_ViewType=block;
    ViewAlias {
    block=GDSII;
    Tool GDSII {}
    i know that the data.reg is being red because I deliberate syntax error it  and make sure virtuoso complain.
    thx
    meny
  • henker
    henker over 5 years ago in reply to mlea11
    Actually the lines from the first post showed 'gdsLay' in the 'Type' selection field in LibraryManager when I tried it, so there might be some other reasons that it did not work on your side.
    However, on the second post: the data.reg has dfII_ViewType=block; while the deRegApp on the first has ?viewType "gdsLay"; Although it is unclear if you also modified the deRegApp, these two entries should be same.
    Also on the elements of the string for viewNameToTypeList: first is the viewname and second is the corresponding viewtype, so "gdsLay gds" would put "gdsLay" to the viewname field when viewtype "gds" is selected; but your actual naming suggests the opposit.
  • mlea11
    mlea11 over 5 years ago in reply to henker
    thx for the response . here is the final code , that is still 50% operational:
    // Data Register file for adding netscape and pdf views
    // Date: 08/21/2013
    DataFormat Netscape {
    Pattern = netscape_url.htm;
    Default_Editor = Netscape;
    dfII_ViewType = netscape_url;
    Co_Managed = netscape_url.htm master.tag prop.xx;
    DataFormat Gdsii {
    Pattern=block.gds;
    Co_Managed= block.gds master.tag;
    DataFormat Acroread {
    Pattern=document.pdf;
    Preferred_Editor=Acroread L;
    dfII_ViewType=document;
    Co_Managed=document.pdf master.tag ;
    ViewAlias {
    netscape_url=Netscape;
    document=Acroread;
    block=Gdsii;
    Tool Netscape {}
    Tool Acroread {}
    Tool Gdsii {}
    envSetVal("graphic" "viewNameToTypeList" 'string "pdf pdf, pdf document, OOo document.od, document document.od*, block block.gds")
    the string "block" dont appear at the  cell view type field, while all the others do.
    i dont publish the triggers because these are seems to load fine , and the required action of launching the wrapper "run_ic_workB"  works.
  • henker
    try this:
    Pattern=block.gds;
    ViewAlias {
    document=Acroread;
    block=run_ic_workB;
    Tool Netscape {}
    Tool Acroread {}
    Andrew Beckett over 5 years ago in reply to henker
    If you use the original SKILL code from the first post (which had ?viewType "gdsLay"), and this in the data.reg, it should work:
    DataFormat Run_ic_workB {
    Default_Editor = Run_ic_workB;
    ViewAlias {
    gdsLay=Run_ic_workB;
    Tool Run_ic_workB {}
    The Default_Editor needs to have a corresponding Tool name in the data.reg. The dfII_ViewType needs to match the ?viewType in the deRegApp. That's about it...
    I agree though - this is not very obvious and easy to get wrong, with little feedback when it's wrong (it simply doesn't work).
