  3. About dbCreateHierProp() method
  • Views 12416
knowledgeseeker
knowledgeseeker over 5 years ago
hi
I confused the output of prop of a hierarchical property.
In the lecture note page 1.55. of SKILL Language Programming 6.1.8, it says the prop attribute of a hierarchical property is always nil.
But actually i test the code below, its output is not nil.
code in lecture note
hp = dbCreateHierProp( cv "TrHierProp" )
hp~>a = 1
hp~>b = 2
hp~>prop => nil
It is right that the prop attribute of a hierarchical property is always nil?
Thank you.
    This is wrong (it hasn't been updated). In CDB (the old database in IC5141 and before), hierarchical properties always had prop as nil, whereas in OpenAccess, the prop attribute is a list of the properties…
    This is wrong (it hasn't been updated). In CDB (the old database in IC5141 and before), hierarchical properties always had prop as nil, whereas in OpenAccess, the prop attribute is a list of the properties within the hierarchical property.
    In essence it is the same as hp~>value. The normal way of accessing all the hierarchical properties would be to use hp~>value to see the member properties, which works in CDB and OA, but in OA using hp~>prop works too.
    I'll feed this back to the course developer.
  • knowledgeseeker
    knowledgeseeker over 5 years ago in reply to Andrew Beckett
    Thank you for answering :)
