  3. Skill code to generate symbol view automatically from s...
  • Views 17587
Skill code to generate symbol view automatically from schematics
Nader Fathy
Nader Fathy over 5 years ago
I have a PDK library that has hundreds of cells, each has a layout and schematic view imported from (GDS and SPICE Netlist). I am trying to write a SKILL code to loop on all cells with schematic view and generate a symbol view for it. I don't care about how fancy the symbol looks, any symbol would work for me. So far I know how to select the library, loop on cells and check if it has a schematic view, however I don't know what function or set of functions to use to generate a simple symbol.
Any help is much appreciated.
OS: Redhat 7
Virtuoso Version: IC6.1.8-64b.500.15
Kindest Regards,
Nader Fathy
  • mbracht
    mbracht over 5 years ago +1
    Hi Nader, Well to create a new empty(!) symbol you can use dbOpenCellViewByType: (dbOpenCellViewByType <lib> <cell> <view> "schematicSymbol" <mode>) Or maybe that wasn't the question was it? M…
    Andrew Beckett over 5 years ago in reply to mbracht +1
    Probably what you're after is: schPinListToSymbol(lib cell "symbol" schSchemToPinList(lib cell "schematic")) Andrew
  • mbracht
    Hi Nader,
    Max
  • Nader Fathy
    Nader Fathy over 5 years ago in reply to Andrew Beckett
    This is exactly what I was looking for. Thank you both for your help.
    Nader Fathy
