  3. virtuoso stream in by SKILL code question
  • Views 14112
GGLin
GGLin over 5 years ago
importCommand = strcat("strmin -library " libName " -strmFile " layoutPath " -logFile " libName "_in.log" )
system(importCommand )
Currently I use the code above to import 2 GDS file into different lib then I want to create a new cell, which the 2 gds top cell are placed in this new cell.
But I faced a problem that the the code after system command won't wait the system command completed and then I cannot get the cellview in the import lib.
and i also try the xstInDoTranslate and i found the same behavior
Is there any way to fix this problem or a better way to do this?
    I don't see why the system() command wouldn't be blocking - if you do system("sleep 30") it certainly blocks. Perhaps "strmin" is a wrapper which backgrounds the process? (that doesn't happen with the Cadence strmin as far as I know).
    If you look in the documentation, you can make xstInDoTranslate by doing:
    xstInSetField("virtualMemory" "true")
    xstInDoTranslate()
    There is also the xstInOnCompletion() callback you can defined which gets called when xstInDoTranslate has finished - so this could be an alternative way of achieving the same thing.
  • GGLin
    GGLin over 5 years ago in reply to Andrew Beckett
    thanks!
