  3. Scaling the X (time) axes of a trace in skill / ocean
  • Views 12277
Simon T
Simon T over 5 years ago
I am extracting data with a skill script and I want to scale the X axes of the traces.
I looked through the docu and forum but could not find a easy way to do it, hence I did it by hand.
Now I am wondering if there is a neat way to do it.
To scale the Y axes one can simply multiply it with a scalar.
Here is the snippet I use:
Fullscreen 3007.x_scaler.txt Download
(procedure (abWaveToList wave @key transpose)
    (let (xList yList xyList len
            (xVec (drGetWaveformXVec wave))
            (yVec (drGetWaveformYVec wave))
        (setq len (drVectorLength xVec))
        ; Return value of this if is the list
        (if transpose
            (progn
            (for i 0 (sub1 len)
                (setq xList (tconc xList (drGetElem xVec i)))
                (setq yList (tconc yList (drGetElem yVec i)))
            (list (car xList) (car yList))
        ; else
            (progn
            (for i 0 (sub1 len)
                (setq xyList (tconc xyList (list (drGetElem xVec i)
                (drGetElem yVec i))))
            (car xyList)
        ) ; if
    ) ; let
) ; procedure
trace = getData("node_of_interest")
fprintf(trace_file "Time[ns] volts\n")
foreach( point trace_as_list
    fprintf(trace_file "%.16f %.16f\n" (car(point) / 1e-9) nth(1 point))
fprintf(trace_file "\n")
closeResults(cur_res_path)
Best,
Simon
    Hi Simon,
    I found that I wrote this a few years ago for another customer
    /* abScaleXaxis.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Dec 21, 2015
    Modified
    By
    Scale the x-axis by a factor
    Note this only works with non-harmonic data (so if it's harmonic-indexed
    data, extract one harmonic at a time first using the harmonic() function)
    abScaleXaxis(wave 2.0)
    SCCS Info: @(#) abScaleXaxis.il 12/21/15.14:47:07 1.1
    procedure(abScaleXaxis(wave scale)
      cond(
        (drIsWaveform(wave)
          let((new)
            new=drCreateWaveform(drGetWaveformXVec(wave)*scale
              drGetWaveformYVec(wave))
            famSetExpr(new `(abScaleXAxis ,famGetExpr(wave) ,scale))
            new
        (famIsFamily(wave)
          famMap('abScaleXAxis wave scale)
        (t
          error("abScaleXaxis: Can't handle %L\n" wave)
