  3. Virtuoso graphical window - get absolute scale
  • Replies 13
  • Views 9017
caver456
caver456 over 5 years ago
What's the best way to determine the absolute scale (in the same definition as hiZoomAbsoluteScale) of an existing window?  I'd like to set one window to have the same absolute scale as another window - even if the windows are different sizes / aspect raios.
  • skillUser
    skillUser over 5 years ago
    I think you need hiGetViewBBox()
    hiGetViewBBox(
      [ w_window ]
    )     => l_bBox
    So you don't get a 'scale' just the viewing area as a bounding box.
    Best regards,
    Lawrence.
    Andrew Beckett over 5 years ago in reply to skillUser
    Lawrence,
    You beat me to it. I was just looking at some very old code to copy the zoom level of one window to another:
    /* abCopyWinView.il
    Author     A.D.Beckett
    Group      Structured Custom, Cadence Design Systems Ltd
    Machine    SUN
    Date       Apr 25, 1994
    Modified
    By
    Copies a window view from one window to another,
    not necessarily of the same cellView
    SCCS Info: @(#) abCopyWinView.il 11/20/08.15:26:12 1.1
    (procedure (abCopyWinViewCB win done points)
      (let (bbox)
           (setq win (hiGetCurrentWindow))
           (when (and done (windowp win) (windowp abCopyWinViewFrom))
                 (setq bbox (hiGetViewBBox abCopyWinViewFrom))
                 (hiZoomIn win bbox))))
    *             (abCopyWinView @optional (win nil))              *
    *     Procedure to copy a view from one window to another      *
    (procedure (abCopyWinView @optional (win nil))
      (unless win (setq win (hiGetCurrentWindow)))
      (setq abCopyWinViewFrom win)
      (hiSetCurrentWindow win)
      (when (windowp win)
            (enterMultiRep ?prompts '("Point to the source window" "Point to the destination window")
                           ?points '((0 0))
                           ?doneProc "abCopyWinViewCB"
                           ?dontDraw t
      t)
    The absolute scale could be computed (if you were really keen on doing so) by figuring out the ratio between the cellView bBox and the hiGetViewBBox (I'm assuming it will be the greater or smaller of the width or height ratios, but that's a guess and I've not done the experiments). I'm not sure how useful that would be.
  • caver456
    caver456 over 5 years ago in reply to Andrew Beckett
    Thanks - that was generally my guess too: get the ratio of hiGetViewBBox to hiGetAbsWindowScreenBBox.  I was hoping for a reciprocal function to hiZoomAbsoluteScale, something like hiGetAbsoluteScale.
    For context, this is to help in the general "make this layout look like layout that" task, where 'this' is not initially identical to 'that' meaning that a cell copy isn't sufficient / doesn't get you all the way there.  Also I found the Background Cellview functions - those are excellent for a quick visual XOR of sorts, but that method also doesn't fit the bill all of the time.  So I set up a zoom-linking thing that basically just intercepts all the zoom and pan and scroll bindkeys, and applies them to multiple windows, making sure to keep the windows centered on the same spot.  (I tried hiRegZoomPanProc - it has some bugginess that remains even after unregistering the zoomPanProc.)  I've been zoom-linking for a bit and determined that it would be even more helpful to have both windows forced to the same absolute scale as well.
    Andrew Beckett over 5 years ago in reply to caver456
    If you want them at the same absolute scale, and centred in the same spot, then I think you'd just use hiGetViewBBox and hiZoomIn - that would effectively do the same thing - they'd both be showing the same zoom area, which I think is in effect the same as what you're asking...
  • caver456
    Not sure if that works when the windows are different sizes.  hiZoomIn uses relative scale - hopefully once the windows are initially set to the same absolute scale, then you can do the same relative zooms from then on.
    No, it doesn't. It zooms to an absolute bounding box. hiZoomRelativeScale zooms using a relative scale, and that's not what I'm using here.
    I originally wrote this code 27 years ago to allow me to have two windows open (such as an extracted view and a layout view, or two layout views on the same design) and replicate the zoom region in one window from another (even if the windows are different sizes).
    There's not really a concept in the window itself of keeping track of an "absolute scale".The absolute scale is just a means of determining how much of the overall bounding box of the cellView should be displayed in the window.
  • caver456
    Ah - sorry bout that, I was thinking of hiZoomInAtMouse / hiZoomOutAtMouse / hiZoomWindowAtMouse etc that use relative scales.  Anyway I will give this code a shot verbatim - I didn't grasp initially that it should be a full solution.  Thanks
  • RK56
    RK56 over 5 years ago in reply to Andrew Beckett
    We can achieve the similar functionality with the help of hiRegZoomPanProc(). I use this to sync two windows simultaneously.
    -Ramakrishnan
  • caver456
    caver456 over 5 years ago in reply to RK56
    I had high hopes for hiRegZoomPanProc but I kept encountering errors like this, which remained even after I unregistered the proc:
    ; `>a^\(window(2) list(list(-194.00000 -754.96400) list(3243.78600 2389.96400)))
    ; SYNTAX ERROR found at line 1 column 2 of file *string*
    ; *Error* lineread/read: syntax error encountered in input
    This is on IC6.1.7-64b.500.18.  All in all it seemed a bit less spooky / a bit more controllable to just intercept the pan/zoom operations.
    But, I would be very curious to see your implementation.  Thanks
  • caver456
    caver456 over 5 years ago in reply to caver456
    Hi Andrew, I did try your code - I think was jut not clear about my use of the term "scale".  What I'd like to do is match the pixels-per-micron from one window to another, so that e.g. a 3-microon-wide-resistor in one large window, zoomed such that it is an inch wide on the screen, would also take one inch on the screen when viewed in a much smaller window.  If the two windows are identically sized, then your code accomplishes this pixels-per-micron matching.  I guess my use of the term 'absolute scale' was incorrect.
