  3. Exspressions in NLPLabel
  • Views 11449
Aldo2
Aldo2 over 5 years ago
I have a Verilog-A block that uses a parameter "my_param"
Using an NLPLabel in the symbol I can view the current value of "my_param": [@my_param]
Now suppose to assign a variable "my_var" to the parameter: is it possible, in case through skill code, to show also the variable name?
E.g.: my_param = my_var
        my_var = 15
        [@my_param] shows "15.0"
        I would like to show also the name of the variable assigned to the parameter: "my_var 15.0"
Thank you
Regards
Aldo
