  3. "Dynamic" submenus in a slider menu
  • Subscribers 150
  • Views 1774
kkdesbois
kkdesbois over 5 years ago
Hello, I created this case 46532196 before discovering this forum.
So, let me expose my expectation :
In my skill code, I'm used to create manually the submenus according to the number I need. Like that :
                     (hiCreateSliderMenuItem ?name 'SwapModels
                        ?itemText "slider title"
                        ?disable nil
                        ?subMenu (hiCreatePulldownMenu 'SubMenu "SubMenu"  (list
                                    (hiCreateMenuItem ?name 'item1
                                                      ?itemText "submenu1"
                                    (hiCreateMenuItem ?name 'item2
                                                      ?itemText "submenu2"
I would like to create the same type of menu but dynamically, i.e without knowing by advance the number of submenus.
A list would contain the submenus' names.
For example : l_submenus= (list "submenu1" "submenu2")
Is it doable?
Kk.
    If you've already opened a case, I won't respond here to avoid duplicating work with a colleague. The forum guidelines ask you not to post a question here if you've already got a case open for that reason.
    Sorry!
  • kkdesbois
    kkdesbois over 5 years ago in reply to Andrew Beckett
    ok. sorry for the duplication.
    I'll wait for the case's answer
