  3. scaling pin spacing - ideas on imposing a minimum between...
  • Views 1323
scaling pin spacing - ideas on imposing a minimum between pins
aicdesigner
aicdesigner over 5 years ago
I find it handy to space pins out and blow up their names (so that all pin names are visible when schematic is "fit" ) as the schematic gets bigger.
The opposite function which brings pins closer together can be handy when working with symbols.
As you can see, the increasing-spacing function works ok. If anyone has ideas on how to enforce a minimum (of 2x snapSpacing) spacing from nearest neighbour, I'd be very grateful if you could share). The existing code obviously doesn't do that..
; smartIncPinSpace( "+" ) ; or "-"
procedure( smartIncPinSpace( space )
let( ( direction unitsep obj count snapSpacing newx min_x min_y sum_sq_x sum_sq_y sum_x sum_y
x y x_p y_p x_table y_table var_x var_y aligned_x aligned_y k_scale k_x k_y
newy firstx firsty firstxy lastxy add)
snapSpacing = envGetVal("schematic" "symSnapSpacing")
; when we do the actual scaling, we'll work in units of snapSpacing
if("+" == space then
k_scale = 1.2
else
k_scale = 0.8
; build up hashtables of the pin coordinates - on for x, one for y and values are the counts
x_table = makeTable( "" 0 ) ; arguments are "print name" and default value
y_table = makeTable( "" 0 )
min_x = nil
count = 0
sum_sq_x = 0
sum_sq_y = 0
sum_x = 0
sum_y = 0
aligned_x = 0
aligned_y = 0
foreach( obj geGetSelSet()
if( obj~>pin
then
x = xCoord( obj~>xy )
y = yCoord( obj~>xy )
if( ! min_x
then
min_x = x
min_y = y
else
min_x = min( min_x x )
min_y = min( min_y y )
x_table[ x ]++
y_table[ y ]++
sum_sq_x += x*x
sum_sq_y += y*y
sum_x += x
sum_y += y
count++
else
geDeselectObject( obj )
foreach( key x_table
if( x_table[key] > 1
aligned_x++
foreach( key y_table
if( y_table[key] > 1
aligned_y++
if( aligned_x == aligned_y
then
; look at spreads
var_x = ( sum_sq_x - sum_x*sum_x ) / count
var_y = ( sum_sq_y - sum_x*sum_y ) / count
else
var_x = 0
var_y = 0 ; just so this doesn't intefere with anything
if( ( aligned_x > aligned_y || var_x < var_y )
then
; means you increase y spacings
k_y = k_scale
k_x = 0
else
; increase x spacings
k_y = 0
k_x = k_scale
) ; might be a way to compact this if into something more elegant
x = xCoord( obj~>xy ) - min_x
y = yCoord( obj~>xy ) - min_y
if( k_y > 0 && y > 0
then
y_p = snapSpacing * round( k_y * y/snapSpacing )
if( k_y > 1 && y_p == y
y_p += snapSpacing
if( k_y < 1 && y_p == y
y_p = max( 2*snapSpacing, y_p-snapSpacing)
obj~>xy = list( x + min_x, y_p + min_y)
else
if( k_x > 0 && x > 0
then
x_p = snapSpacing * round( k_x * x/snapSpacing )
if( k_x > 1 && x_p == x
x_p += snapSpacing
if( k_x < 1 && x_p == x
x_p = max( 2*snapSpacing, x_p-snapSpacing)
obj~>xy = list( x_p + min_x, y + min_y)
) ; foreach
); let
); procedure
