  3. "undefined function defclass" when making a context fil...
  • Views 2382
"undefined function defclass" when making a context file
EssenZh
EssenZh over 5 years ago
Greetings all,
I found the declass undefined issue recently when converting a skill file to the context file with virtuoso version 6.1.8.
To make things simpler, I create a test file, just define a class in it, run the below command and get the error.
virtuoso -ilLoadIL  ./test.il -nograph
*Error* eval: undefined function - defclass
test.il:
setContext("test ")
defclass( globalClass ()
        (var1 @initform nil)
saveContext("test.cxt")
exit()
If I replace –ilLoadIL with –replay, which is not the right way to create the context, then it can pass. There must be something not initialized when using -ilLoadIL.
Any ideas?
Essen
    Essen, You need (as outlined in the "Delivering Products" chapter of the SKILL Language User Guide) load any necessary context files yourself if using the -ilLoadIL argument. In this case it needs the…
    Essen,
    You need (as outlined in the "Delivering Products" chapter of the SKILL Language User Guide) load any necessary context files yourself if using the -ilLoadIL argument. In this case it needs the skillCore context file - add this to the beginning of your file before the setContext:
    loadContext(prependInstallPath(strcat("../" getSkillVersion() "/context/skillCore.cxt")))
  • EssenZh
    EssenZh over 5 years ago in reply to Andrew Beckett
    Thank you so much, Andrew. I realized that I have a function to load the context, but did not find the right skillCore.cxt.
    Looks like I still can compile my other SKILL script without skillCore, but when I compile SKILL++, skillCore is required, that is the reason I got the failure.
    Thank you and have a good day.
