  3. Adding fields to form programmatically
  • Views 13947
dragank
dragank over 5 years ago
Hi all.
Is there a way to add string field ("hiCreateStringField") to existing form?
I am trying to do something like:
formFields = plotterForm->fieldList
upToCornerSelection = list()
upToCornerSelection = append1(upToCornerSelection car(formFields))
upToCornerSelection = append1(upToCornerSelection cadr(formFields))
upToCornerSelection = append1(upToCornerSelection caddr(formFields))
afterCornerSelection = cdddr(formFields)
insertionFields = list()
rangeLabel = list(hiCreateLabel(?name 'rangeLabel ?labelText "Range") 200:100 95:28)
insertionFields = append1(insertionFields rangeLabel)
foreach( cvn cornerVariations->?
newStringField = hiCreateStringField(
?name stringToSymbol(strcat("strip" sprintf(nil "%d" rowCounter) "StringField"))
?prompt sprintf(nil "%d" rowCounter)
newStringField = list(newStringField 0:100+dY*rowCounter 270:28 100)
insertionFields = append1(insertionFields newStringField)
newFieldsList = append(upToCornerSelection insertionFields)
newFieldsList = append(newFieldsList afterCornerSelection)
plotterForm->fieldList = newFieldsList
rowCounter = rowCounter + 1
Thank you in advance.
    You can't just update the list. You need to call hiAddField or hiAddFields to add them - see this example for details.
  • dragank
    dragank over 5 years ago in reply to Andrew Beckett
    I replaced misused code and now I have:
    dY = 30
    rowCounter = 1
    insertionContainer = cadddr(formFields)
    rangeLabel = list(hiCreateLabel(?name 'rangeLabel ?labelText "Range") 0:50 100:28)
    hiAddField(insertionContainer rangeLabel)
      hiAddField(insertionContainer newStringField)
     insertionContainer gets evaluated as "hiCreateScrollRegion"
    I need it as a contained to populate fields programmatically.
    But no luck so far.
    I have CIW Error:
    *** Error in routine error:
    Message: *Error* hiAddField: argument #1 must be a form struct, scroll region, or hiLayout.
    Entering new debug toplevel due to error:
    Andrew Beckett over 5 years ago in reply to dragank
    Debugging this without seeing all the code is rather difficult - I suggest you contact customer support. Otherwise we're sailing blind!
  • dragank
    Thanks again.
    I added "dyn_" prefix to dynamically populated fielda, so I can distinct them from static fields.
    This way I can add  them and remove them programmatically  as needed.
