  3. SKILL command to select figs or polygons under given po...
  • Views 13518
SKILL command to select figs or polygons under given points
Shiva Kalgi
Shiva Kalgi over 5 years ago
Can you help me with SKILL command or code to select figs or polygons under given point?
e.g. Need to select all figs or polygons under (10.0 10.0) coordinate.
Shivanand
    xy=10.0:10.0 cv=geGetEditCellView() foreach(fig dbGetOverlaps(cv list(xy xy)) geSelectFig(fig) ) The geSelectPoint() function could have potentially been used, but that only selects a single object under…
    xy=10.0:10.0
      geSelectFig(fig)
    The geSelectPoint() function could have potentially been used, but that only selects a single object under the point at a time, and I don't think it would be very efficient to keep selecting until the selected set gets no larger.
  • Shiva Kalgi
    Shiva Kalgi over 5 years ago in reply to Andrew Beckett
    It is working...
    Thanks Andrew for the quick turn around.
