  3. axlGetPointPsfDir error
  • Views 12397
dragank
dragank over 5 years ago
Hi all.
I am trying to get psfDir as:
psfDir = axlGetPointPsfDir(hist test ?cornerName cj ?designPointId 1)
But, i get error in log:
*Error* funcall: argument #1 should be a function object or name (type template = "ug") - nil
I tried various variations by hardcoding values for function arguments but none of them returns directory to do openResults(psfDir) later and to getData to extract waveforms.
Has anyone had similar scenario ?
  • dragank
    My mistake. " hist"  should be history_id.
    Andrew Beckett over 5 years ago in reply to dragank
    Are you saying that you've solved it? I'm not really sure what the name of the variable has to do with this working or not...
  • dragank
    dragank over 5 years ago in reply to Andrew Beckett
    Right argument is identifier of history, not the name.
    Thank you.
    OK - I'm not sure that I could have known that hist was the name of the history rather than the id. I guess that's always the danger with showing one line of code out of context.
    Anyway, glad you've resolved it.
