  3. Automatically reverse bus order in schematic
  • Replies 8
  • Subscribers 150
  • Views 9959
FormerMember
FormerMember over 5 years ago
when I import a netlist into a schematic and enable the automatic bus merging, the order is always ascending, even though the schematic options are set to descending. It seems there is no option, to alter this behaviour.
At the moment, I always have to manually select the pins in the generated schematic and change the bus order, which also updates all nets.
My idea is, to use a skill script to automatically do this. However, when I access the terminal object and try to just change the name, I get an error "Terminal with name ... already exists". This also does not take care of the labes and wire names. I already found an old answer from Andrew -> https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill/12896/how-to-programtically-rename-a-selected-pin but this does not seem to be completely what I need.
Best regards
Paul
    Paul,
    What kind of netlist are you importing, and which IC sub-version are you using? Just so that I can focus my attention in the right place...
  • FormerMember
    FormerMember over 5 years ago in reply to Andrew Beckett
    Its the same circuits I mentioned here -> https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/47255/spicein-fails-for-existing-symbol-with-bus-pins
    I have a Spice netlist with bus pins, which I want to import into an existing cell. Since the import does not work directly, I import it into a dummy cell and want to copy the schematic to the actual cell. However, because the bus order and pin directions are wrong, I have to manually edit the schematic every time.
    The virtuoso version I use is ICADVM20.1-65b.500.17 (it should be fairly recent)
    Andrew Beckett over 5 years ago in reply to FormerMember
    Paul,
    There does appear to have been one request for control over the order, but it was voided because the customer decided they didn't need it after all. So you might want to request control over the order via customer support.
    This code (I think) should do the job (at least from my very simple testing):
    procedure(CCFreverseBusOrder(@key (cv geGetEditCellView()) (check t) save)
        let((busPattern)
            busPattern=pcreCompile("^(\\w*)<(\\d+):(\\d+)>$")
            ; First wire labels
            ; Note this is not attempting to rename buses which are part of
            ; a bundle
            foreach(shape cv~>shapes
                when(shape~>objType=="label" && shape~>layerName=="wire" &&
                        pcreExecute(busPattern shape~>theLabel)
                    shape~>theLabel=pcreSubstitute(busPattern "\\1<\\3:\\2>")
            ; Then the terminals
            foreach(term cv~>terminals
                when(pcreExecute(busPattern term~>name)
                    ; Slightly messy approach - can't directly rename the terminal
                    ; as it complains about existing terminal, so temporarily add
                    ; a dummy prefix and then rename back again
                    term~>name=pcreSubstitute(busPattern "_RbODuMMy\\1<\\2:\\3>")
                    term~>name=pcreSubstitute(busPattern "\\1<\\3:\\2>")
            when(check
                schCheck(cv)
            when(save
                dbSave(cv)
            t
  • FormerMember
    Thank you, this works well for me. I modified it slightly to also take care of the pin direction. It seems, you already solved every problem at some point in the past Slight smile
    If only! I wrote the code yesterday (didn't take long) in response to this. I also ended up filing two CCRs:
    2498066 Merge BusBits produces incorrect schematic with square bracket as delimiter
    2498083 SPICEIN with Merge BusBits fails if symbol already exists
    (the second one was the issue you mentioned in your previous post - I didn't see one filed, so I thought I'd do it whilst I had the test case ready).
  • RK56
    RK56 over 5 years ago in reply to Andrew Beckett
    Whatever you write on the fly like this one, are they part of any skill code library in support site? I know there is a skill code library in support site but do these code snippets get added over there? Any plan of doing so?
    It would be useful
    -Ramakrishnan
    Andrew Beckett over 5 years ago in reply to RK56
    Hi Ramakrishna,
    Sometimes I do create articles for code I post here - but it's additional effort and I don't always have time to put together a full description and publish it as an article. Specifically adding into the "SKILL Library" is not something I typically do (I must admit I don't know who owns that these days), although I do typically get any articles I write related to calculator functions added into the SKILL calculator functions library (as that process is something I am aware of).
    Since support.cadence.com also searches the community, it's not necessarily a requirement to specifically publish an article. For example, if you use the  "All Content" search and search for CCFreverseBusOrder then it will find this thread...
  • RK56
    I understand. Thank you.
    -Ramakrishnan
