  3. combobox dependent on another combobox virtuoso skill
  • Replies 8
  • Views 15065
saurabh96
saurabh96 over 5 years ago
I have created two combo box 1 and 2, respectively. Combo box contains tech nodes like 40nm or 60 nm. Combo box2 contains rules like rule1,2.
now When I select 40nm from the combo box, i should only see rule 1 and three ..same wise when I select 60nm, rule3 and four select, and others should not be visible.
How to get this using skill code?
  • mbracht
    mbracht over 5 years ago +1
    Hi, You need to set up the callback of the nodes combo box so as it repopulates the choices of the rules combo box: (let (techNodes rules theForm) techNodes = (hiCreateCyclicField ?name 'techNodes…
  • mbracht
    mbracht over 5 years ago in reply to saurabh96 +1
    The way you assign key/value pairs to the table in your code is not valid SKILL syntax. I assume what you wanted to do is this: rules["60nm"] = rules["50nm"] = ... = rules["90nm"] = (list "rule1" "rule4
  • mbracht
    You have two problems in your code - for one you create just one of the two combo boxes and then in hiCreateAppForm() you are adding the SKILL table as a field. Here's a working example: (let (techNodes…
  • mbracht
                      ?name 'techNodes
                      ?prompt     "Tech Nodes"
                      ?choices    (list "40nm" "60nm")
                      ?callback   (lambda (fld form node)
                                     (println node)
                                     (case node
                                        ("40nm"
                                           theForm->rules->choices = (list "Rule1" "Rule2" "Rule3"))
                                        ("60nm"
                                           theForm->rules->choices = (list "Rule1" "Rule4")))))
       rules = (hiCreateCyclicField
                      ?name 'rules
                      ?prompt     "Rules"
                      ?choices    (list "Rule1" "Rule2" "Rule3"))
       theForm = (hiCreateAppForm
          ?name 'myForm
          ?formTitle "Just playing..."
          ?fields (list techNodes rules))
       (hiDisplayForm theForm)
  • saurabh96
    saurabh96 over 5 years ago in reply to mbracht
    Thanks mbracht,
    I got the flow..one more thing , I have to ask to suppose if I have to define it for 20+ tech nodes and the same as more than 20+rules...how we can define it in as code length will be much longer if I pick each node and define the rule in front of them...How can we list and define by that?
  • mbracht
    I'm not sure whether I understand what you mean - so I'm just guessing.  I take it that you have a long list of nodes and each one has their own rules and you don't want to hard code that in the case statement in the callback - am I correct? In that case I would accomodate the node/rule relation ship in a SKILL table which is essentially a hash table.
    rules = (makeTable 'nodesTbl nil)
    rules("40nm") = (list "rule1" "rule2" ...)
    rules("60nm") = (list "rule1" "rule4" ...)
    ...and then in the callback replace the entire case statement against:
    theForm->rules->choices = rules[node]
    But maybe I just don't understand your problem.
    Max
  • saurabh96
    Thanks Max for quick reply,
    you guess it partially right..let me elaborate you.
    Suppose i have long list of nodes as well as long list of rules...so if i define different rule in each single node then runtime and syntax length  will be more?I have tried this way..pls correct where am wrong.
    ?name 'techNodes
    (println node)
    theForm->rules->choices = rules[node]))
    rules("40nm"  "80nm" "120nm" "100nm"  "150nm" "140nm"= (list "rule3 "rule2" "rule7"...)
    rules("60nm" "50nm" "90nm" "110nm"  "130nm" "180nm") = (list "rule1" "rule4"  "rule9"...)
    ?name 'myForm
  • mbracht
    rules["60nm"] = rules["50nm"] = ... = rules["90nm"]  = (list "rule1" "rule4"  "rule9"...)
  • saurabh96
    ok...
    here is correction i have done
    ?name 'techNodes
    ?choices (list "40nm" "60nm" "50nm" "90nm" "10nm" "80nm" )
    (println node)
    rules["60nm"] = rules["50nm"] =rules["90nm"] = (list "rule7" "rule2" "rule9")
    rules("10nm") = rules["40nm"] =rules["80nm"] = (list "rule1" "rule4")
    ?name 'myForm
    While running above file in CIW window am getting an error of -
    *Error* putprop: argument #3 should be either a string or a symbol (type template = "ggS") - nil
  • mbracht
    (let (techNodes rules rulesTbl)
       rulesTbl = (makeTable 'rulesTbl nil)
       rulesTbl["60nm"] = rulesTbl["50nm"] =rulesTbl["90nm"] = (list "rule7" "rule2" "rule9")
       rulesTbl["10nm"] = rulesTbl["40nm"] =rulesTbl["80nm"] = (list "rule1" "rule4")
                      ?name 'techNodes
                      ?choices    (list "10nm" "40nm" "50nm" "60nm" "80nm" "90nm")
                                     theForm->rules->choices = rulesTbl[node]))
                      ?name 'rules
                      ?prompt     "Rules"
                      ?choices    (list "rule1" "rule4"))
          ?name 'myForm
  • saurabh96
    Thanks alot Max ...i got the flow
