  3. removing signals in the pivot table
  • Views 12052
sv srini
sv srini over 5 years ago
Hello
1.Iam trying to write a skill script to export the scalar values at the end of a single run, sweeps and corners and also Montecarlo sampling in a pivot ready format.
I use the command ( for eg)
maeExportOutputView(?session axlGetWindowSession() ?fileName "./mc3.pivot.xlsx" ?view "Detail - Transpose" ?historyName "MonteCarlo.1.RO")
to export the results  , but this also contains some blank colums that correspond to the waveforms .
When I manually uncheck the signals in the results tab and repeat this , i get what i want , but would like to be able to do this using skill to avoid the manual unchecking every time. I would like the signals in maestro gui , but not in the pivot table.
2. In the results summary tab, the order of the columns displayed is /Test , output , Min , Mean . Max etc . Is there a way to change this / reorder using maestro variables  in skill ?
srini
    I don't think the first is possible currently - other than using:
    envSetVal("adexl.gui" "detailtransposeViewShowDefault" 'string "\"Scalar Expressions\"  \"Corner Expressions\" \"Sweep Expressions\" \"Top Level Expressions\" \"Device Checks\"")
    before the maestro view is opened, and then it also affects the UI - so not what you want. I couldn't see a request to do this, but it seems a reasonable enhancement request for an argument to maeExportOutputView to specify which types of outputs you wish to export. You should contact customer support.
    I don't believe the second is possible either - there's a cdsenv for controlling the summary view too, but it doesn't have that fine control (the env var is summaryViewShowDefault)
