  3. How to open a new gui window from pull down option using...
  • Views 14562
How to open a new gui window from pull down option using skill in virtuoso ciw
saurabh96
saurabh96 over 5 years ago
Hi i create a pull down option halo it consists of setup and guide..now i want that when i click setup a new gui opens..for that i have written skilll code but cannot merge..How to do that when i click setup a new gui opens ..Also for that new gui below is skill code am using.
(let (techNodes rules theForm)
   techNodes = (hiCreateCyclicField
                  ?name 'techNodes
                  ?prompt     "Tech Nodes"
                  ?choices    (list "40nm" "60nm")
                  ?callback   (lambda (fld form node)
                                 (println node)
                                 (case node
                                    ("40nm"
                                       theForm->rules->choices = (list "Rule1" "Rule2" "Rule3"))
                                    ("60nm"
                                       theForm->rules->choices = (list "Rule1" "Rule4")))))
   rules = (hiCreateCyclicField
                  ?name 'rules
                  ?prompt     "Rules"
                  ?choices    (list "Rule1" "Rule2" "Rule3"))
   theForm = (hiCreateAppForm
      ?name 'myForm
      ?formTitle "Just playing..."
      ?fields (list techNodes rules))
   (hiDisplayForm theForm)
  • mbracht
    mbracht over 5 years ago +1
    Hi, You need to put the code in the let() block in a global function and then define this global function as the menu item's callback: (defun setupItemCB () (let (techNodes rules) techNodes = (hiCreateCyclicField…
  • mbracht
                         ?name 'techNodes
                                        (println node)
                                        (case node
                                           ("40nm"
                                           ("60nm"
                         ?name 'rules
                         ?prompt     "Rules"
             ?name 'myForm
          (hiDisplayForm theForm)))
    setupItem = (hiCreateMenuItem
       ?name 'Setup
       ?itemText   "Setup"
       ?callback   "setupItemCB()")
    userGuideItem = (hiCreateMenuItem
       ?name 'UserGiude
       ?itemText   "User Guide"
       ?callback   "(println \"to be implemented...\")")
    haloMenu = (hiCreatePulldownMenu
       (gensym)
       "Halo"
       (list setupItem userGuideItem))
    (hiInsertBannerMenu window( 1 ) haloMenu (length (hiGetBannerMenus (window 1))) )
  • saurabh96
    saurabh96 over 5 years ago in reply to mbracht
    Thanks Max ..for quick guidance and reply.
    Max i was testing one of the skill code..i have few questions in that:-
    1) How can we call netlist direct from schematic using radio button in gui.?
    2)Suppose from browse button we had to only call .gds or .cdl file and if user select other than these two extension file will not be select. How we can do it using skill in browse button option?
    button_setup_data = hiCreateButton(
    ?name 'button_setup_data
    ?buttonText "Browse"
    ?callback "ddsFileBrowseCB(hiGetCurrentForm() 'setup_data_path \"\" '.cdlOnly)" )
  • mbracht
    mbracht over 5 years ago in reply to saurabh96
    I think you should open a new thread for this - the original question about how to pop up a GUI through a pull down menu is definitely answered.
    You also need to be clearer with your questions, I don't really understand what you mean by "call netlist direct from schematic using radio button in gui"
    Max
