  3. How to implement a browse button in such a way that when...
  • Views 13018
How to implement a browse button in such a way that when user brows it can only pick the .cdl or .gds file extension..not other than that using skill?
saurabh96
saurabh96 over 5 years ago
How to implement a browse button in such a way that when user brows it can only pick the .cdl or .gds file extension..I have tried this way.
button_tech_data = hiCreateButton(
?name 'button_tech_data
?buttonText "Browse"
?callback "ddsFileBrowseCB(hiGetCurrentForm() 'tech_files \"\" '.cdlfileOnly)" )
while running in ciw window its showing error that .cdlfile is error
    I've no idea why you've added '.cdlfileOnly - that has no special meaning and is an invalid value for the fourth argument to ddsFileBrowseCB. The filter argument is similar to that for hiCreateFileSeparatorField…
    Andrew Beckett over 5 years ago in reply to saurabh96 +1
    saurabh96 said: while running in ciw am getting this warning info:- Well, clearly you've made a typo, and given that you've not posted the code that actually produces that error, I'm afraid my psychic…
    I've no idea why you've added '.cdlfileOnly - that has no special meaning and is an invalid value for the fourth argument to ddsFileBrowseCB. The filter argument is similar to that for hiCreateFileSeparatorField (although it must start with a *), with the ability to have multiple filters which are separated by a double semi-colon. So this does what you want, I think:
    ?callback "ddsFileBrowseCB(hiGetCurrentForm() 'tech_files \"*.cdl;;*.gds\")"
  • saurabh96
    saurabh96 over 5 years ago in reply to Andrew Beckett
    Thanks Andrew i got the error.
    WARNING* (reader): string at line 1 was not terminated on EOF, '"' added
    at line 2 of string "...orm() 'tech_files "*.tvf
    *WARNING* (reader): a '(' at line 1 was still unclosed on EOF, ')' added
    at line 2 of string "...rm() 'tech_files "*.tvf
    Well, clearly you've made a typo, and given that you've not posted the code that actually produces that error, I'm afraid my psychic powers don't enable me to determine what you've mistyped.
    I might hazard a guess though that you've forgotten to put a backslash before an embedded quotation mark within the callback string.
  • saurabh96
    Oh,i got the error..Thanks Andrew for reply..my mistake for not posting in brief :))
    cheers!
