  3. How to switch off and on the String fields option using...
  • Views 14104
How to switch off and on the String fields option using radio button
saurabh96
saurabh96 over 5 years ago
I have created two radio button 1 and 2 respectively and below that two string fields 1 and 2 with browse button for each .Now I want that when I select radio button 1, string filed 2 automatically gets disabled and when I select radio button 2, string filed 1 get disabled.
How to create it using SKILL GUI.
I am new to the skill. Any guidance will be appreciated.
    You'd call a callback function from the radio button fields which then calls hiSetFieldEnabled with the string fields to enable them or not.
  • saurabh96
    saurabh96 over 5 years ago in reply to Andrew Beckett
    Hello Andrew,
    Thanks for quick reply.
    Although am still getting error and warning ...
    net= hiCreateStringField(
    ?name 'net
    ?prompt "Enter Netlist Path"
    ?value ""
    button_net_data = hiCreateButton(
    ?name 'button_net_data
    ?buttonText "Browse"
    ?callback "ddsFileBrowseCB(hiGetCurrentForm() 'net \"\" 'fileOnly)"
    libNameField = hiCreateStringField(
    ?name 'libName
    ?prompt "library_name"
    ?value ""
    browseSourceButton = hiCreateButton(
    ?name 'browseSource
    ?callback "dmbSyncWithForm(AppForm 'browse 'libName 'CycField)"
    netlists=hiCreateRadioField(
    ?name 'netlists
    ?prompt ""
    ?choices list("Netlist Path" "Cell View")
    ?value "Cell View"
    ?enabled t
    ?callback list("(hiSetFieldEnabled() 'netlists 'net '(t nil ) ;;)"
    Andrew Beckett over 5 years ago in reply to saurabh96
    Your callback was completely wrong. I've no idea how you ever thought that would work as it seems a fairly random set of words you've put in the string, rather than actually being code (hiSetFieldEnabled is a function that needs two arguments, and you've provided no arguments). Perhaps you should follow the SKILL Language Programming course on http://support.cadence.com ?
    I updated the code (I added a very simple form at the end just to prove it works), so you wouldn't need that bit. I call the callback after the form is created just to set the initial enabled/disabled settings appropriately:
      ?name 'net
      ?value ""
      ?name 'libName
      ?value ""
      ?name 'browseSource
      ?name 'netlists
      ?prompt ""
      ?value "Cell View"
      ?enabled t
      ; no idea how this was supposed to work - it's a random set of values!
      ;?callback list("(hiSetFieldEnabled() 'netlists 'net '(t nil ) ;;)"
      ?callback list("MyEnableFields(hiGetCurrentForm())")
    procedure(MyEnableFields(form)
      let((netEnabled)
        case(form->netlists->value
          ("Cell View"
            netEnabled=nil
          ("Netlist Path"
            netEnabled=t
        hiSetFieldEnabled(form->net netEnabled)
        hiSetFieldEnabled(form->button_net_data netEnabled)
        hiSetFieldEnabled(form->libName !netEnabled)
        hiSetFieldEnabled(form->browseSource !netEnabled)
    hiCreateAppForm(?name 'forum86 ?fields list(net button_net_data libNameField browseSourceButton netlists))
    MyEnableFields(forum86)
    hiDisplayForm(forum86)
