  3. How to hide or expose different options
  • Views 13255
saurabh96
saurabh96 over 5 years ago
Hey..
is there any way to hide or expose certain string field  based on options from combo box .Suppose if i choose "a" from combo box then string filed "x" gets hide or disappear not disabled and when selected "b" its appear?
    myform->field1->invisible=t
    will make the field invisible. If you set the invisible property to nil it will reappear again.
  • saurabh96
    saurabh96 over 5 years ago in reply to Andrew Beckett
    Thanks for charm response...here what i have implement and getting confused/error how to callback local variable in another procedure ... i tried that and getting error when i select  technode is "60nm" or "80nm'' my string and button data gets hidden.
    (let (techNodes rules rulesTbl string button_data)
       rulesTbl = (makeTable 'rulesTbl nil)
       rulesTbl["60nm"] = rulesTbl["50nm"] =rulesTbl["90nm"] = (list "rule7" "rule2" "rule9")
       rulesTbl["10nm"] = rulesTbl["40nm"] =rulesTbl["80nm"] = (list "rule1" "rule4")
       techNodes = (hiCreateCyclicField
                      ?name 'techNodes
                      ?prompt     "Tech Nodes"
                      ?choices    (list "10nm" "40nm" "50nm" "60nm" "80nm" "90nm")
                      ?callback  list(("MytechFields(hiGetCurrentForm())") ("MyhideFields(hiGetCurrentForm())") )
       rules = (hiCreateCyclicField
                      ?name 'rules
                      ?prompt     "Rules"
                      ?choices    (list "rule1" "rule4"))
    string = hiCreateStringField(
    ?name 'string
    ?prompt "chk"
    ?value ""
    button_data = hiCreateButton(
    ?name 'button_data
    ?buttonText "Browse"
    ?callback "ddsFileBrowseCB(hiGetCurrentForm() 'string \"\" 'fileOnly)"
       theForm = (hiCreateAppForm
          ?name 'myForm
          ?formTitle "Just playing..."
          ?fields (list techNodes rules string button_data))
       (hiDisplayForm theForm)
    procedure(MytechFields(form)
    (lambda (fld form node)
    theForm->rules->choices = rulesTbl[node]))
    procedure(MyhideFields(form)
    case(form->technodes->value
    ("60nm"
    myform->string->invisible=t
    Andrew Beckett over 5 years ago in reply to saurabh96
    There were very few lines in your code that didn't have an error of some sort. Between missing (or mismatched) parentheses, misspelt variable names, failing to access field values, unnecessary lambdas, and a callback argument that was just some random use of lists, very little was correct.
    I would strongly suggest you follow SKILL training as mentioned in a previous post, or at the very least look at my video: Writing Good SKILL Code (Video)
    I've reformatted your code to make it easier to read - as I mention in the video, using consistent indentation tends to help with readability and also spotting mistakes. Using bracket matching in an editor really helps too to find mistakes. Or just reading the documentation and taking some training (it's not clear to me that you have much programming experience as regardless of the language most of these things ought to have been pretty easy to spot).
    (let (techNodes rules rulesTbl)
       ; close brackets were missing too here, and callback is nonsense
          ?name 'techNodes
          ; original bad  callback
          ;?callback  list(("MytechFields(hiGetCurrentForm())") ("MyhideFields(hiGetCurrentForm())") )
          ; two space-separated callback functions - calls one then the other
          ?callback  "MytechFields(hiGetCurrentForm()) MyhideFields(hiGetCurrentForm())"
          ; alternative implementation with new function which does both changing choices and controls
          ; visibility
          ;?callback  "MytechAndHideFields(hiGetCurrentForm())"
          ?name 'rules
          ?prompt     "Rules"
          ?name 'string
          ?prompt "chk"
          ?value ""
       ; close brackets were in wrong place (after the hiDisplayForm)
          ?name 'button_data
          ?name 'myForm
    ; WARNING - the functions below rely on dynamic scoping - the rulesTbl variable is
    ; defined in the let above, and it's only visible here because the form is blocking,
    ; and the hiDisplayForm is within the let. You need to be careful not to change that
    ; behaviour because otherwise this will stop working (i.e. if you don't call hiDisplay
    ; within the let).
       ; no idea why you'd put a lambda here - absolutely unnecessary to create an anonymous function
       ; when you're actually creating a named function!
       ;(lambda (fld form node))
       ; the variable name was also wrong (theForm) plus the node wasn't being retrieved from the form
       form->rules->choices = rulesTbl[form->techNodes->value]
       ; you'd misspelled techNodes as technodes in the case
       case(form->techNodes->value
          ("60nm"
             ; form variable was wrong here - you'd used myform (lowercase). Either
             ; use form (the variable passed in) or the global variable theForm
          ; added a default clause so that there is some way of making it visible again
          (t
             form->string->invisible=nil
       ; were missing two close parentheses here
    ; alternative implementation - combined both into one function
    procedure(MytechAndHideFields(form)
          ("60nm"
          (t
