  3. Add symbols from library to schematic library
  • Views 13481
TravisMN
TravisMN over 5 years ago
I have a list of over 1000 gate schematics to which I need to add symbols. I have been attempting several commands to achieve this, but it is only producing errors and incorrect results. This is my first task assigned for using Cadence, so I have no familiarity with this at all. What are the correct commands and syntax to copy the symbols to the respective schematic? Is there a way to automate this for the whole library? This following example libraries and cells are what I am using below:
Symbol source: "local_symbols" Cell: "and2"
Schematic source library: "TravisMN_test" Cell: "AND2_X10_12TLVT"
I attempted to use:
schPinListToSymbol("local_symbols" "and2" "symbol" schSchemToPinList("TravisMN_test" "AND2_X10_12TLVT" "schematic"))
as mentioned in post https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill/47924/skill-code-to-generate-symbol-view-automatically-from-schematics/1373961, but produced a generic rectangle symbol instead of the AND gate I am attempting to map to the schematic and it also did not combine the symbol to the schematic.
    If you just want to copy the symbol, using schSchemToPinList and schPinListToSymbol won't help. schPinListToSymbol is intended to produce an automated symbol from a list of pins, and will be a generic rectangular symbol. Plus the fact your code would overwrite the local_symbols/and2 symbol which is presumably not what you wanted!
    You'd just do:
    srcCv=dbOpenCellViewByType("local_symbols" "and2" "symbol")
    dstCv=dbCopyCellView(srcCv "TravisMN_test" "AND2_X10_12TLVT" "symbol")
    dbClose(srcCv)
    dbClose(dstCv)
