  3. How to know if a procedure is already defined by hiRegC...
  • Subscribers 150
  • Views 12156
How to know if a procedure is already defined by hiRegCloseProc
kkdesbois
kkdesbois over 5 years ago
I'd like to define a procedure when closing the ADE-L window.with the function hiRegCloseProc
Is there a way to know if a procedure has already be defined for this window?
Thanks.
  • kkdesbois
    It seems that some procedures are alredy associated to the closing of ADE-L and they are running before mine (UartCornerCloseOpenedSetupCorners).
    Can my procedure be launched before the other one?
    Regards.
    Andrew Beckett over 5 years ago in reply to kkdesbois
    You could use hiUnregCloseProc to unregister 'UartCornerCloseOpenedSetupCorners, then register your function, then re-register the original function (or you could just call the original function from your own close proc - whichever you wish).
