  3. Getting Path Properties Whilst Being Placed
  • Views 14703
kdolan
kdolan over 5 years ago
I want to create a function that can obtain a paths bounding box whilst the user is still placing the path.  i.e. the user has used the create path command and is adding path points, but has not clicked the enter key yet to fully place the path object.
I've tried using geGetSelSet() but it returns nil because I guess the path is not 'selected', and instead is still being created. I've been looking around and haven't come across a function or method that can do this.
Any ideas or input is appreciated!
Thanks in advance for any help.
Keelan
  • skillUser
    skillUser over 5 years ago +1
    Hi Keelan, the only way that I know to do something like this is to use an Enter function, e.g. enterPoints() so you can control the gathering of the points and can trigger functions while the enter…
    Andrew Beckett over 5 years ago in reply to kdolan +1
    Hi Keelan, I spoke with the presenter of the tech talk, and as I suspected (I missed it, because I was busy at the time) they had just defined a SKILL function to toggle an environment variable on or…
  • skillUser
    Hi Keelan,
    the only way that I know to do something like this is to use an Enter function, e.g. enterPoints() so you can control the gathering of the points and can trigger functions while the enter function is active (it has 'addPoint' and 'deletePoint' procedures, for example, that are triggered for those events). You should be able to search for some examples in this forum and on the Cadence support site.
    Hope this helps!
    Lawrence.
    Andrew Beckett over 5 years ago in reply to skillUser
    I'm also wondering (beyond Lawrence's suggestions) what exactly you're trying to do here - it seems a bit odd trying to find the bounding box of something you've not actually created yet, so I can't imagine what you're trying to do.
  • kdolan
    kdolan over 5 years ago in reply to Andrew Beckett
    Thank you both for your quick responses. What I am trying to do, or more so replicate, is a script I saw at your 'Maximizing Custom Layout Productivity Even as the Circuit Changes' Tech Talk a few days ago.
    I believe the presenter referred to the skill script as 'auto via drop', whereby as the presenter was overlapping paths with the same net names, vias were automatically placed.
    I came across a previous thread (Automatic VIA Drop for same NET - Custom IC SKILL - Cadence Technology Forums - Cadence Community) that did something very similar, but I didn't like the idea of having to specify the area. I've looked at other via functions but haven't managed to replicate what I believe was shown.
    Hi Keelan,
    I spoke with the presenter of the tech talk, and as I suspected (I missed it, because I was busy at the time) they had just defined a SKILL function to toggle an environment variable on or off. They'd done this:
    (defun CCSViaDrop ()
      (envSetVal "layout" "weAutoDropViaForOverlaps" 'boolean (not (envGetVal "layout" "weAutoDropViaForOverlaps")))
    (hiSetBindKey "Layout" "<Key>0" "CCSViaDrop()")
    So pressing the 0 key toggled on or off the auto via drop on overlaps, rather than requiring you to explicitly use the Create Via command and then use "auto" mode and click on the overlapping regions. Put another way, it's enabling or disabling a standard feature of the tools, rather than running a SKILL function to do the via auto-filling.
  • kdolan
    Ah yes, that is working perfectly and doing what I wanted. A little bit less complicated than the route I way taking!!
    Appreciate all your help as usual!
    Keelan
  • ebecheto
    ebecheto over 5 years ago
    Hi kdolan,
    You found what you need with the graphical tool.
    But for the sake of the questions, i find interesting to share with you a way to do it in skill.
    defun(bBox2array (@optional (bBox list(0:1 2:3))) let((X0 Y0 X1 Y1)
    X0=caar(bBox);=> 0
    Y0=cadar(bBox);=> 1
    X1=caadr(bBox);=> 2
    Y1=cadadr(bBox);=> 3
    list(X0:Y0 X1:Y0 X1:Y1 X0:Y1)))
    procedure( trBBoxIntersection( bBoxList )
        let( ( llxList llyList
            urxList     uryList
            maxllx      maxlly
            minurx      minury      )
            llxList = foreach( mapcar bBox bBoxList
                xCoord( lowerLeft( bBox )))
            llyList = foreach( mapcar bBox bBoxList
                yCoord( lowerLeft( bBox )))
            urxList = foreach( mapcar bBox bBoxList
                xCoord( upperRight( bBox )))
            uryList = foreach( mapcar bBox bBoxList
                yCoord( upperRight( bBox )))
            minurx = apply( 'min urxList )
            minury = apply( 'min uryList )
            maxllx = apply( 'max llxList )
            maxlly = apply( 'max llyList )
            cond(
                ( maxllx >= minurx nil )
                ( maxlly >= minury nil )
                ( t
                    list( maxllx:maxlly minurx:minury ))
                ) ; cond
          ) ; let
    ) ; procedure
    cv=geGetWindowCellView()
    techFile = techGetTechFile(cv)
    constraintGroupId = cstFindConstraintGroupIn(techFile "virtuosoDefaultSetup")
    myViaOptions = viaGetViaOptions(constraintGroupId)
    myViaOptions~>createInRoute = nil
    path1=dbCreatePath(cv "M1" list(0:0 0:50 ) 10)
    path2=dbCreatePath(cv "M2" list(-20:20 20:20 ) 12)
    path1~>bBox;=> ((-5.0 0.0) (5.0 50.0))
    path2~>bBox;=> ((-20.0 14.0) (20.0 26.0))
    bBox=trBBoxIntersection(list(path1~>bBox path2~>bBox));=> ((-5.0 14.0) (5.0 26.0))
    array=bBox2array(bBox);=> ((-5.0 14.0) (5.0 14.0) (5.0 26.0) (-5.0 26.0))
    viaGenerateViasInArea(cv array myViaOptions);=> output lot of blabla in virtuoso
    Hope it helps,
    Regards
