  3. How to delete/change test variable in Assembler
  • Views 2493
alexstepanov75
alexstepanov75 over 5 years ago
I need to change test design variables in Assembler. (Update some variable values and delete others)
I didn't find way to update value of design variable or to delete specific variable.
The only option I found is to delete all variables like this:
sess=axlGetWindowSession()
sdb=axlGetMainSetupDB(sess)
sevSess=axlGetToolSession( sess testName)
asiSess=sevEnvironment( sevSess)
asiSetDesignVarList( asiSess nil)
And then needed variables can be added using axlPutVar()
Is it a better way to do this?
    If this is for Assembler, the best way is to use maeSetVar: maeSetVar("Cload" "200f" ?typeName "test" ?typeValue list("TRAN_AC")). ; the typeValue is the list of test names. Might also want to add ?session…
    maeSetVar("Cload" "200f" ?typeName "test" ?typeValue list("TRAN_AC")). ; the typeValue is the list of test names. Might also want to add ?session sess if it's not the current session.
    Unfortunately maeDeleteVar can't currently be used to delete a test/design variable - CCR 2481922 is asking for this (it's a fairly recent request from one of the product engineering team, so it would be a good idea to contact customer support and request a duplicate as that could have a similar use model to maeSetVar). To delete a test variable, you can do that with the axl APIs:
    test=axlGetTest(sdb "TRAN_AC")
    var=axlGetVar(test "data_rate")
    axlRemoveElement(var)
  • alexstepanov75
    alexstepanov75 over 5 years ago in reply to Andrew Beckett
    Thank you!
